**Aeromotive Stealth Fuel Pumps Wiring Notice!** - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 10-11-2011, 04:23 PM Thread Starter
Yaadman_GT's Avatar
I know that it has been widely disseminated that if you are running the new Aeromotive Stealth 340lph Fuel Pumps, whether in a Fore, or other billet fuel hat designed for Walbro 255s or stock fuel hangars; that you have to de-pin the connector and switch the β€œ+” and β€œ-β€œ wires in the connector itself to get the right connection on the Aeromotive pumps.
Now for the note - **THIS ONLY APPLIES TO THE AEROMOTIVE PUMPS THAT HAVE A WHITE COLORED INLET SIDE!!**
If you have recently purchased these pumps, there is a possibility that the pumps you bought have a RED INLET SIDE. If you have one of these, then you DO NOT need to de-pin the connector and switch the wires. Aeromotive realized this issue on the WHITE INLET pumps, and fixed it with the new run of pumps with the RED INLET.
Nothing destructive will happen; you just won’t have fuel pressure and the pumps will be running backwards (blowing instead of sucking up fuel).
If you have already put the tank in and filled f up with fuel like I did, you can just swap the wires in the trunk. Please cut and solder your connections!
FRANZ aka THA JAMAICAN
2002 BLACK FORD MUSTANG GT (TURBO)!!
Yaadman_GT is offline
post #2 of 2 Old 10-28-2011, 02:42 PM
92cleancoupe's Avatar
Trader Feedback: (44)
Haha I put my stealth pump in without re-wiring it and was not happy when I had to drop the tank again to fix it! Make sure you check this!
Work's awesome though, I trapped 129 mph @3400 lbs with this pump,stock lines, and 42s!
92cleancoupe is offline
carb conversion redfox89 5.0/5.8 Engine Tech 6 11-11-2013 09:20 AM
For Sale NEED FUEL INJECTORS OR FUEL PUMPS....SPECIAL PRICING FOR CORRAL MEMBERS!!!! Muscle Motors Performance Fuel System & Related 12 03-17-2013 01:07 PM
Fuel pump wiring 97stanger97 GT & SOHC 10 06-29-2011 11:17 PM
Fuel System: wiring issues DBlack1 General Mustang Tech 2 06-07-2011 07:00 PM
For Sale 42lb inj, mass air, aeromotive reg., fuel pumps 347mustang Fuel System & Related 10 03-22-2011 10:38 PM
