Anyone tried replacement headlight switch from LRS? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 10-03-2011, 07:12 PM Thread Starter
I finally had the headlight issue get me the other night and it seems Ford wants a small fortune for their replacement switch. Granted, the backside of my switch is not melted (yet) and looks great (can it be saved?) - I am interested in this replacement unit:
1987-93 Mustang GT Headlight Switch, Reproduction at LRS - Same Day Shipping!
I checked out the Borg Warner replacement at Auto Zone and while it's very close to the original, the finish of the black plastic is not the same as OEM. Anyone know if the LRS unit is like OEM in this regard?
Thanks,
eric
fastsvo is offline
post #2 of 7 Old 10-15-2011, 06:07 PM Thread Starter
anyone? Bueler?
fastsvo is offline
post #3 of 7 Old 10-17-2011, 08:53 PM
Blown88GT's Avatar
You have to replace more than the headlamp switch. If it's not melted, it's probably okay.
Ford TSB 89-17-11 says this is caused by overheating in the headlamp circuit. You'll need to replace the headlamp and dimmer switches, several connectors, and then bypass the wiring in the circuit with new 12ga wire run alongside the original harness.
If you don't use the fog lights, you will likely never experience the problem.
1988 GT, 57k mi, Orig Owner
Blown88GT is offline
post #4 of 7 Old 10-17-2011, 10:32 PM Thread Starter
What's wrong with doing the headlight switch mod w/o replacing any of the original parts (granted they are ok)?
fastsvo is offline
post #5 of 7 Old 10-19-2011, 12:13 AM
indy2000's Avatar
the switch is fine, the problem is the current going thru the MFS(aka turn signal)
if you have had the lights flick on and off the MFS is hooped.
you need to do the relay or TSB or else you will damage the new MFS.
MFS is even more $$ if its still avail.
indy2000 is offline
post #6 of 7 Old 10-19-2011, 02:35 AM Thread Starter
Well the lights were turning off by themselves but not flickering. I would just turn them back on myself and then I quickly remembered this was a common issue and turned off the fog lights.
fastsvo is offline
post #7 of 7 Old 10-19-2011, 08:34 AM
indy2000's Avatar
they will come off and on, as the problem gets worse.
the slider inside the hi and low beams thru the mfs will eventually break.
its plastic and is begining to melt.
indy2000 is offline
Want To Buy 93 mustang headlight switch jestang Interior Parts 1 09-25-2011 09:48 PM
85 headlight switch connector king_coopa_85stang General Mustang Tech 3 03-27-2011 11:57 PM
94/95 Headlight switch question SLOPONY 94/95 Tech 1 12-14-2010 08:32 AM
possible headlight switch problem? MERRICKD General Mustang Tech 8 01-07-2002 06:19 AM
Broken Headlight Switch David1969 General Mustang Tech 1 01-02-2002 03:53 AM
