91 GT spark and fuel pump issue - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 10-02-2011, 06:25 PM Thread Starter
Ok I got a 1991 GT vert. Car was running perfectly fine. I added a turbo kit to it and did a simi wire tuck. Didn't really extend anything other than the MAF wire a bit and the air intake temp wires. Everything else I just pulled it through the stock holes in the fenders and basically hid it in the fender well. Haven't put the front end on either cause I was wanting to make sure everything was going to be working properly before I did. Anyway went to start it up and nothing. Just turns over. Wasn't getting spark and the fuel pump wasn't priming. So I did a little research after I went back over all the wiring to make sure nothing was unplugged and all the grounds was hooked up. Found out the relay for the fuel pump is under the seat. Pulled it out and put power to the green/yellow wire that was going to the relay and you could hear the FP stay turned on. It still wouldn't start. Theres another relay by the MAF which I read the later models 92 up have a fuel pump relay there. So I took the relay off and put power to a red wire that went to that relay and you could ghear the pump prim and shut off like its supposed to. The car starts up runs for a few sec and dies with power going to that red wire. I tried hitting the throttle after it starts but it doesn't do anything. Soooo if anyone has any suggestions with what may be wrong it would be great.
mr2gq is offline
post #2 of 3 Old 10-02-2011, 11:09 PM Thread Starter
I hooked a power wire to the green and yellow wire thats in the relay plug under the seat and one to the red wire in the relay plug by the MAF and when its hooked up like that it will stay running. So im out or guesses lol
mr2gq is offline
post #3 of 3 Old 10-03-2011, 08:36 AM Thread Starter
Anyone?
mr2gq is offline
** Northeast For Sale Thread ** SVTCobraLTD Northeast 4255 09-13-2019 04:50 PM
no start, fuel pressure cobraman1024 94/95 Tech 11 10-27-2014 08:37 PM
98 GT Won't start. No Injector Pulse. No power to fuel pump. Shawn 94 GT GT & SOHC 11 10-23-2012 07:48 AM
Want To Trade 93 coupe drag/street 418 2 stages juiced418 Other Fords and Trades 8 08-16-2011 02:02 PM
For Sale 2001 Mustang GT 5.1L Fully Built 600+hp 06Xrunner Mustangs For Sale/Wanted, 1999-2004 13 11-06-2010 12:36 PM
