85 gt-eliminating voltage regulator?3g alt - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 09-28-2011, 11:34 PM Thread Starter
nick5oh's Avatar
looking to get rid of the factory voltage regulator on my car. its still wired in to the upgraded 3g alternator thats installed.if i disconnect the factory regulator the 3g will not charge.
also....just checking on proper connections with the d-shaped and power cable conections......
1 the big power cable goes directly from battery to alternator stud
2 the white/black stripe wire goes to the plug on alternator beside d-shaped plug
3 the yellow???
4 the green/red striped???
yellow and green/red are switched 12 volts for which wire and ? for the other wire?
thanks guys
Stock parts 302,E7 heads,bolt down rockers,air gap, 650DP,small HR cam,1&5/8"LT's,bullets dumped, 4.10, 26x10S,2800lbs,TKO500,Team Z
[email protected]+MPH,1.48 60',NEED MORE GEAR
nick5oh is offline
post #2 of 4 Old 09-29-2011, 06:03 AM
f2fast4u's Avatar
Oh gosh, I removed my factory voltage regulator over ten years ago when I upgraded to 3G on my 84 5.0L and used the internal regulator on the 3G instead.
Perhaps contact that company that always advertises 3G and alternator upgrades in the magizines and see if they have converter wiring.
I'd literally have to go unwrap my wiring (buried inside that 342 stroker, headers) engine area to tell what the colors matched up to now.
But the good news it's an easy thing to do (I know because I did it way back then with no help!).
f2fast4u is offline
post #3 of 4 Old 10-06-2011, 08:13 PM
Warlock1's Avatar
Trader Feedback: (23)
Warlock1 is offline
post #4 of 4 Old 10-11-2011, 10:28 PM Thread Starter
nick5oh's Avatar
so can i hook the green/red stripe wire on the alternator harness to the green/red stripe wire that runs into the factory voltage regulator? it is switched 12v? im assuming you can hook it to any switched 12v wire right?
nick5oh is offline
Got a new shipping scale and started weighing items, T5, stock hood, fender, heads Speeds8erM-1 General Mustang Tech 107 04-08-2013 05:48 PM
For Sale 2006 GT Take off Parts allballsmustang S197 and Coyote Parts 0 11-24-2010 11:35 AM
Want To Trade Gt 5spd for gt auto bikeboyben14 Mustangs For Sale/Wanted, 1987-1993 6 11-21-2010 11:09 PM
Want To Trade WTT 2 fox mustangs For 1 85 GT hatch or SVO 88LK5.0 Mustangs For Sale/Wanted, 1979-1986 0 11-18-2010 08:04 AM
V6 to V8 swap questions tvanlant 94/95 Tech 8 11-10-2010 09:31 PM
