anti slosh - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 09-26-2011, 06:37 PM Thread Starter
anti slosh
Is there any way I can just install a new gas gauge, instead of try to find a replacement . The car is an 89.
musto12366 is offline
post #2 of 3 Old 09-27-2011, 08:03 PM
The fuel and oil pressure gauges have to be replaced at the same time since they are a single assembly, but if the slosh module is bad then replacing the gas gauge isn't going to fix the problem. You would have to find another cluster and hope it has a good module.
A common problem with the module seems to be with solder cracking around the main contacts. Have you checked the large solder pads for cracking around the contacts? It will look like a circular pattern in the solder. The pads can be reheated to reflow the solder and it only take a few seconds.
Saleen0679 is offline
post #3 of 3 Old 09-27-2011, 08:21 PM Thread Starter
Have to give it a try
87-89 Anti Slosh Module FIX *PLZ COMIN* MnIrishJr Electrical & Wiring 17 07-10-2011 09:19 PM
For Sale rear calipers, rear Cobra pads, anti moan brackets PeeJx5x Suspension 5 06-14-2011 04:21 PM
Want To Buy ANTI SLOSH MODULE MnIrishJr Electronics and Entertainment 0 05-20-2011 09:37 PM
Want To Buy anti moan braces for 1996 cobra tazmandevil Suspension 0 04-14-2011 01:05 AM
For Sale Team Z Motorsports Anti Roll Bar ARB Stylin97 aka 97-V6 Suspension 4 02-09-2011 06:52 PM
