Check engine light HELP!!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 09-17-2011, 03:20 PM Thread Starter
Boostedstang96's Avatar
Ok so I have an off road X pipe and I have the code P0156 on. I have the MIL eliminators. So aren't they supposed to shut that light off or will it come on if the O2 sensors are bad. Please help I am trying to sell this car and don't want that stupid light on.
SPEED KILLS DRIVE A HONDA!!!
Boostedstang96 is offline
post #2 of 5 Old 09-22-2011, 07:37 PM Thread Starter
Any words of Wisdom for me??
post #3 of 5 Old 09-23-2011, 02:17 AM
I am not sure what the mil eliminator is. But most likely the PCM is detecting an open circuit in the o2 heater.
93 Twintrbo is offline
post #4 of 5 Old 09-23-2011, 02:33 AM Thread Starter
It's the Malfunction Indicator light eliminators when you have an off road h pipe. So as far as the open circuit where do I start and how do I check for such things. I checked the plugs out and the one plug is burnt a little but the wires look good.
post #5 of 5 Old 10-19-2011, 11:19 PM Thread Starter
Any ideas? I tried swapping sensors to see if the code would change but the right sensor would not come out then i checked the codes after I put the left one back in and now i have codes for both sensors. P0156-P0141-P0131 i think those are the right codes. Should I try and buy new sensors?
Noisy Aluminator engine WesStang SVT & DOHC 13 10-26-2011 06:21 PM
CEL only comes on when off the tester fiore1230 Electrical & Wiring 1 07-08-2011 02:43 PM
s-trim installed now check engine light and idle surge? killer5-0 General Mustang Tech 12 06-25-2011 11:58 PM
Check engine light with 3inch exhaust bwd1973 General Mustang Tech 4 03-27-2011 11:15 PM
Check engine light came on momentarily while driving BenW 94/95 Tech 5 01-12-2002 03:48 PM
