help indentify wires to fuel pump relay to toggle switch - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 09-15-2011, 11:18 PM Thread Starter
I have a 89 gt converted to carb im running 2 relays to toggle switches one for my holley blue pump,one for my electric fan. Im using 2 stock 4 pin relays from exsiting harness wires are orange with blue stripe, pink,yellow, red. which one do i run to power pump? and which for power on which one ground,which one for toggle?
hatchdemon89 is offline
post #2 of 6 Old 09-23-2011, 08:01 PM Thread Starter
50 something views and no luck hmmmm
post #3 of 6 Old 09-29-2011, 06:15 AM
f2fast4u's Avatar
When I did my '90 from EFI to carb, I went online to eBay and found the 1990 Ford Mustang Electrical and Vacuum Trouble-Shooting manual, and bought it. Since I own and '84 5.0L that's factory carb'd, I went online to eBay and also purchased Ford's 1984 EVT Manual.
Then I sat down and started comparing wiring harneses. Didn't take long and I then rewired my 1990 for carb with external mounted electricl fuel pump, factory a/c, etc. It was not hard to figure out. However, without those two year specific Ford Manuals it would have taken me a very long time and I'd probably botched it.
The manuals are usually pretty cheap. That'd be my suggestion - at least get a 1989 Ford EVT Manual so you know what you're looking at.
f2fast4u is offline
post #4 of 6 Old 10-04-2011, 07:21 PM
f2fast4u's Avatar
I used the #18 wire from the fuse box in my 1990 to run my electic fuel pump.
f2fast4u is offline
post #5 of 6 Old 10-11-2011, 10:35 PM
nick5oh's Avatar
the relays should be labelled 30,87,85,86. 30 & 87 are your constant power and power to accy (pump/fan etc). 86 & 85 are switched power and ground.
Stock parts 302,E7 heads,bolt down rockers,air gap, 650DP,small HR cam,1&5/8"LT's,bullets dumped, 4.10, 26x10S,2800lbs,TKO500,Team Z
[email protected]+MPH,1.48 60',NEED MORE GEAR
nick5oh is offline
post #6 of 6 Old 10-12-2011, 10:35 PM
what if they are labeled 1,2,3,4,5?
sleeper90 is offline
No power to the pump! stangbang411 94/95 Tech 11 06-03-2011 01:52 PM
Bad Adjustable FPR, Fuel Pump, or Fuel pump relay..Please help! Daily driver! fomoco30 General Mustang Tech 2 04-03-2011 10:33 PM
Fuel Pump wiring issue? - help Ourobos Electrical & Wiring 10 03-05-2011 02:54 AM
where is Fuel Pump Relay on '88 Mustang? 67stang 5.0/5.8 Engine Tech 4 01-09-2002 12:24 PM
part nubers, fuel pump relay RICEMAN00 GT & SOHC 3 01-08-2002 10:59 AM
