DCC fk50 controller! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 09-12-2011, 03:43 PM Thread Starter
chitwnkid's Avatar
Unhappy DCC fk50 controller!
I have a Dcc fk50 controller installed with my markv111 electric fan! I have been running this for about 3 months now. Question i have is that now my fan quit working. I tested the fan by jumping from the battery and it spins. I also put a volt meter (with the key on) to the ground and power in on the controller and am getting juice to the controller. I then put the +post on the volt meter to the power out on the controller and got nothing at all. so is my controller gone bad or what? I have power going onto the controller, but no power going out from the controller! again the fan works VIA being jumped real quick from the battery. could I contact DDC controller and see what they will do with a replacement? if so does anyone have the phone number or direct web address? Thanks for your help......
chitwnkid is offline
post #2 of 5 Old 09-12-2011, 04:32 PM
Trader Feedback: (41)
Check your sensor. Most of the time the sensor comes out of the radiator and doesn't trigger the fan.
stangjumper is offline
post #3 of 5 Old 09-12-2011, 06:05 PM Thread Starter
chitwnkid's Avatar
controller!
I did check the sensor and it is still installed between the fins! The dcc controller and fan was working great! then now no power from the dcc controller. I have power going to the unit, but no power coming from the unit! my fuses are good, wiring is good! again tested it with a volt meter....good for power going in. not good for power going out. I am wondering if the sensor went bad! maybe the unit(power out is bad) not sure
post #4 of 5 Old 09-12-2011, 08:03 PM
Check the sensor harness with an ohm meter. Cold and hot. The ohms should change. I think he has the ohms vs temperature on his web site.
post #5 of 5 Old 09-17-2011, 08:26 PM
Any problems that i ever had with my unit he was always very helpful to get sorted out.
http://www.dccontrol.com
1988 GT Vert, Work in Progress
pohlmeyr is offline
DCC fan controller? Nemesis96 94/95 Tech 0 07-15-2011 03:07 AM
contour dual fan and DCC fk50 controller 92wikidlx General Mustang Tech 11 06-28-2011 12:25 PM
DCC Temp Probe for the 2sp controller where to mount it 93gtman General Mustang Tech 5 06-24-2011 03:27 PM
Mark V111 fan/dcc fk50 controller! chitwnkid Electrical & Wiring 1 06-21-2011 05:03 PM
For Sale DCC 2 speed controller $75 Shipped boosty Electronics and Entertainment 7 02-23-2011 08:20 PM
