Digital 6 plus problems - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 09-08-2011, 01:32 AM Thread Starter
Hello corral,Im having problems with my digital 6. I had a 6al-2 and the car ran perfect, put the digital 6 on and the car breaks up at 4500 -5500 rpm. I sent the box back to MSD and got a new one and have the same problem.Everything is set right on the box no start retard,no 2step, set on proper setting for 8cylinder.Have anyone had this problem with their digital 6 ? Thanks in advance.
smoke93gt is offline
post #2 of 12 Old 09-08-2011, 07:53 PM
memphis306's Avatar
did you cut the green loop like you were supposed to?
memphis306 is offline
post #3 of 12 Old 09-08-2011, 08:47 PM Thread Starter
Yes green loop is cut.
post #4 of 12 Old 09-08-2011, 09:54 PM
memphis306's Avatar
well,im out of ideas.lol . do you have the manual? if not,i can dig mine up and see if it has a troubleshooting guide
post #5 of 12 Old 09-10-2011, 07:17 AM Thread Starter
Thanks,i have the manual.Anybody else have suggestions?
post #6 of 12 Old 09-13-2011, 05:03 PM
95cobraguy's Avatar
Trader Feedback: (75)
good thing i stumbled upon this thread, i just put a digital 6 plus in my car and had no idea the green loop is supposed to be cut. as far as the ignition breakup, how are the plugs and wires and cap and rotor?
95 Cobra #1679
Copy and paste link for my 363 thread
https://forums.corral.net/forums/5-0-5-8-engine-tech/1283537-fordstrokers-363-pics.html
95cobraguy is offline
post #7 of 12 Old 09-14-2011, 08:00 PM Thread Starter
New wires,plugs, cap and rotor,only thing not changed is the pickup in the distributor.I just got a 8253 coil haven't installed it yet.Plug gap is 32
post #8 of 12 Old 09-15-2011, 12:20 AM
95cobraguy's Avatar
I called MSD today, they told me on a factory ford distributor ignition that the green loop doesn't get cut. The factory distributor doesnt use a magnetic pickup, it uses a hall effect pickup so the green loop doesnt get cut.
95 Cobra #1679
post #9 of 12 Old 09-15-2011, 05:33 PM Thread Starter
I'm running a MSD billet distributor pn#85805.Do i need the green loop cut?
post #10 of 12 Old 09-16-2011, 08:59 AM
95cobraguy's Avatar
the instructions from msd (which are vague regarding this green loop) says that if using an msd billet distributor that the green loop gets cut.
95 Cobra #1679
post #11 of 12 Old 09-20-2011, 11:01 PM
memphis306's Avatar
well,someone at MSD is full of ####,and im betting its the guy you talked to
post #12 of 12 Old 09-26-2011, 08:45 AM
95cobraguy's Avatar
^^^ yea cut it if you're using a factory ford distributor with a magnetic pickup (like on old duraspark ford ignitions), TFI doesn't use a magnetic pickup in the distributor, the pickup is a hall effect sensor. so the green loop doesn't get cut.
95 Cobra #1679
For Sale MSD Digital Multi-Retard Controller nosfed408coupe Electronics and Entertainment 3 07-21-2011 04:52 PM
Nordskog Digital speedometer problems Hella Good General Mustang Tech 1 04-28-2011 01:37 PM
For Sale Digital 6, Digital retard, NoxBox2 progressive Badboss351 Electronics and Entertainment 1 03-09-2011 06:08 PM
MSD Digital 6, anyone have problems? jturmanator General Mustang Tech 12 02-24-2011 10:25 PM
FOR SALE Mackie Digital X Bus Console,Numark CDX Direct-Drive CD Turntable dj2011 S-197 Mustang (2005-2010) 0 02-16-2011 08:25 PM
