Instrument Cluster wiring question - 12V input - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 09-04-2011, 12:50 PM Thread Starter
RAP66's Avatar
Question Instrument Cluster wiring question - 12V input
I'm re-rewiring my dash. Last year I pulled the stock clusted and installed an MC Machine & Autometer setup, at the time I just did what was needed to get everythign working. This is the 3rd or 4th time I've had the dah apart so now I want to re-wire the cluster <the right way>.
Looking at the plugs from the electrical diagram book
I see 12V input (C250) on pins 4 & 7 and on the othert plug (C251) I see Ignition Switch on pin2 & 12V input on pin 7
My question is about the 12V inputs, are these safe to use for lighting as a switched source?
My Current setup I have all of the 12V inputs connected to the Ignition Switch (pin2).
Thanx
1991 Mustang GT: FordStrokers 347, Jay Allen cam, 42#, TFS Heads, GT40, BBK 75mm TB/EGR spacer, 90mm LMAF, T-56, Full MM suspension, SVO brakes, NRC Disc conv., Vortech V3, Kurgan Tune & Meth: 492.4 rwhp/483.1 rwtq @ 12psi
, Phantom II gauges in MC Machine Dash.
RAP66 is offline
post #2 of 4 Old 09-04-2011, 03:59 PM
You should be fine using those connections. C251-2 comes right off of the ignition switch. The other connections come off of fuse 18 and were originally used for the gauges.
Have you considered C251-11 and C250-13 which were originally used for instrument illumination and are controlled by the panel dim switch?
Saleen0679 is offline
post #3 of 4 Old 09-05-2011, 01:27 AM Thread Starter
RAP66's Avatar
yep, did that... I was making sure that the other 12v inputs could be used as switched 12v sources... They work fine I'll post images tomorrow.
RAP66 is offline
post #4 of 4 Old 09-05-2011, 10:49 AM Thread Starter
RAP66's Avatar
images as promised
Before:
After - Replaced the factory plugs and re-wire
Nite shot
RAP66 is offline
pics and a how to for getting an 03 cobra cluster to work in a 96 cobra 03sm3341 SVT & DOHC 1 05-27-2011 12:50 PM
87 GT Instrument Wiring, Check my work camaroz1985 Electrical & Wiring 0 05-18-2011 02:37 PM
Want To Buy 87-89 140 MPH Instrument Cluster ErichWilhelm Interior Parts 2 05-04-2011 11:52 AM
need help ID'ing an instrument cluster stackz88 5.0/5.8 Engine Tech 0 04-14-2011 08:30 AM
Want To Buy 94-04 Instrument Cluster Bezel (See Pics) Det_Riot Interior Parts 3 02-10-2011 07:44 PM
