Powering directly from alternator?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 08-26-2011, 10:19 AM Thread Starter
dart408's Avatar
I have my car wired via the MAD Electric design. This design runs a 8 guage wire directly from the alternator pin to a power distribution block. You then run all of the high load electric items directly from that point ( In my case I run a fan, water pump, and head lights). There is a little more to the system, but that is the short of it.
The guy over at MAD told me it wouldnt affect the longevity or performance of the alternator. I have a few friends that tell me im basically full fielding the alternator and its going to eventually kill it.
Any have experience with this?
dart408 is offline
post #2 of 4 Old 09-10-2011, 12:32 AM
I did mine like that MAD wiring but I recall mine takes 8 ga wire from alternator to silenoid. off same silenoid side i have 1/0 wire to + battery terminal then another 8ga wire going from this same terminal back up to front of car where old silenoid used to be ( i just replaced stock silenoid with studded terminal) Its not directly off alternator but from same point alternator meets battery wire at rear mounted silenoid, no problem so far after 2+ years
88 LX 331 stroker
bart works sla/ mm rear co with phb
MYOWNR is offline
post #3 of 4 Old 09-19-2011, 07:44 PM Thread Starter
dart408's Avatar
Do you run a kill switch?
408 Dart, Fox Lake Vic Jr's, Proformance Racing TH400 , YSI, Holley Dominator EFI
dart408 is offline
post #4 of 4 Old 09-19-2011, 09:15 PM
not nhra legal, mine is in line with the negative wire so it cuts the ground off.
88 LX 331 stroker
MYOWNR is offline
3g Alternator Upgrade DONE!!! oatburner99 5.0/5.8 Engine Tech 37 10-01-2013 03:59 PM
Alternator charging question docstang Road Racing/Auto X 5 08-06-2011 10:01 AM
408 swap: alternator fitment issues (sn95 brackets) 89cobranotch 94/95 Tech 24 04-26-2011 04:55 PM
s-trim ASP smog delete pulley 3g alternator...alternator doesn't fit??? killer5-0 Superchargers 3 04-16-2011 06:28 AM
Which pulley for 3g alternator? Curtis90GT 5.0/5.8 Engine Tech 17 02-10-2002 07:10 PM
