Mark VIII Fan Wiring...different colored wires? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 08-22-2011, 03:44 PM Thread Starter
Hey guys,
I am putting a Mark VIII fan that I bought off of corral in my fox. I have searched, found all kinds of results, and been using this site for my install:
Electric Fan Conversion Using the Notorious Lincoln Mark VIII Fan - FordMuscle
However, every result I look at has the blue wire on the far left (positive) and two black wires to its right (another positive and the ground). My harness on my fan has the blue wire in the center, a light brown with orange stripe where the blue wire is shown (see picture) and the black on the far left. My plan is to use the blue wire as my positive and the black as ground and just seal the brown/orange off with heat shrink. Will this work? Someone told me that the Mark VIII fans have two speeds also so I need to make sure I use the high speed. I am using a variable speed controller (SPAL-PWM). Any input would be greatly appreciated!
1991 Mustang GT/AOD
Blown..........Up
l ShadowFox l is offline
post #2 of 4 Old 08-25-2011, 01:48 AM
The middle wire is the low speed. This fan draws a lot of amps on start up so you may consider upgrading your alternator to a 3G 130 amp.
casey four eyes is offline
post #3 of 4 Old 08-25-2011, 02:58 AM Thread Starter
Already did. Thanks for the response. So I need to use the other positive, correct?
1991 Mustang GT/AOD
Blown..........Up
post #4 of 4 Old 09-02-2011, 09:47 AM
indy2000's Avatar
don't forget freewheeling diode, or you will quickly burn up relay contacts.
indy2000 is offline
For Sale Custom Mark VIII Cooling Fans - Direct Bolt-in Fans! Caseywan Electronics and Entertainment 194 09-28-2014 01:55 PM
For Sale Mark VIII Fan - $80 dcook_14 Modular Engine Parts 5 10-25-2011 08:12 AM
Mark VIII fan, 31x19 radiator, & 3G alternator swap complete Satistraction General Mustang Tech 6 07-15-2002 11:40 PM
SN-95 or Mark VIII elec fan with big Griffin Rad??? Viper Stang 5.0/5.8 Engine Tech 2 12-28-2001 07:39 PM
replacement fan blade for lincoln mark VIII electric fan stang331 5.0/5.8 Engine Tech 1 12-21-2001 01:10 PM
