wiring electric waterpump, do I need relay? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 08-18-2011, 12:18 PM Thread Starter
pillowofwinds's Avatar
Do I need a relay to wire my meziere water pump in, or can I just wire the + side to key on power and ground the negative side? I hate wiring and Ive done soo much of it lately, and the last thing I want to do is have more wires running in the engine bay(just did wire tuck and cleaned it up good). Whats the advantage for running the relay anyway? The guy at meziere said nothing about needing the extra relay harness. It is a street driven car but I figured Id be fine with running it to key on power.
90 lx coupe - too big of heads and too big a cam, 4.10s
10.69 @ 127.8 NA stock bottom end
pillowofwinds is offline
post #2 of 7 Old 08-18-2011, 05:25 PM
460capri's Avatar
Trader Feedback: (48)
I am using a relay but I re-did the whole wiring but the water pumps only takes like 11 amps pretty low amps but personally I would use one . I also hate wiring so I know how you feel but once done its done .
85 Capri 310 , 10.1cr , solid roller cam 608"/614"x 242*/248* AFR 205 heads , 1 3/4" headers , super victor intake , holley 750DP , MSd ignition system and NOS 150 shot .
460capri is offline
post #3 of 7 Old 08-22-2011, 03:09 PM
91BlueGT's Avatar
yes, i would. i relay the fans, fuel pump, and water pump (not running a CSR right now but have the wiring in place for when i put it back on). if anything, saves you from having to run giant switches rated high enough and gives you the ability to run a variety of switches.
i had a switch literally blow up on me while driving (fuel pump). was wired directly from the battery to the switch, then to the pump. twas a small switch.
mech engineer - OKLAHOMA STATE
88 gt hb - 347 all forged, canfield 195cc's, xr282, holley 750, vic jr
89 gt hb - 306, windsor jr's, 70mm turbo, FAST efi, 10pt, vic 5.0, 60lb inj, front wheels off the ground
91BlueGT is offline
post #4 of 7 Old 08-31-2011, 04:12 PM
Trader Feedback: (27)
Definitely use a relay! Keep the high current out of your switches...they last longer.
droopie is offline
post #5 of 7 Old 09-01-2011, 01:49 PM
ACJ
ACJ's Avatar
I use this to run a electric fan and WP
Fan Control
ACJ is offline
post #6 of 7 Old 09-09-2011, 06:35 PM
91BlueGT's Avatar
Fan Control
yeshhhh.
datta boy. +546456
91BlueGT is offline
post #7 of 7 Old 09-11-2011, 04:32 AM
mustangBrad94gt's Avatar
X2 and a fuse on the load side of relay
mustangBrad94gt is offline
For Sale Moroso electric waterpump drive kit FastASH Windsor Engine Parts 13 05-13-2011 07:52 PM
relay wiring question w/pic. steel1 General Mustang Tech 3 01-23-2011 01:41 PM
Fuel Pump Relay wiring - 1986 2.3 to V8 swap Ourobos General Mustang Tech 0 12-01-2010 07:32 PM
Help a wiring retard - RELAY Vettkilr 5.0/5.8 Engine Tech 2 12-16-2001 07:59 AM
