A/C blower - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 08-15-2011, 10:11 AM Thread Starter
bucstang1's Avatar
A/C blower
This weekend the first three positions on My a/c blower stopped working all at once. Only the high setting works. Any suggestions?? Switch maybe ??
bucstang1 is offline
post #2 of 4 Old 08-16-2011, 12:17 AM
Most likely you lost your blower motor resistor. It's mounted on the outside of the blower box with a plug connected to it. You should be able to see it from under the glove compartment. It's mounted with a couple of screws. The resistor is made up of three coil resistors and a thermal limiter. Sometimes the limiter goes bad.
Saleen0679 is offline
post #3 of 4 Old 08-16-2011, 02:07 PM Thread Starter
bucstang1's Avatar
Thanks , I appreciate it. I'll check it out.
post #4 of 4 Old 08-17-2011, 10:11 AM Thread Starter
bucstang1's Avatar
So, I removed the blower motor resistor last night. It was in bad shape (rusted and falling apart) so after some rigging cutting and soldering I managed to rig it enough to work .. for now. Thanks for the suggestion, Now I need to buy a new one before it fails again !!
Idle surge after A/C system stops working Stanglegend01 GT & SOHC 2 08-10-2011 12:45 AM
Blower belt life? Krinkov Superchargers 9 08-03-2011 09:48 PM
For Sale POSI race ported prototype blower for an 03 cobra jimmy8541 Power Adders 1 12-27-2010 06:31 PM
A/C, to get rid of it? cmichael00 Lounge 22 11-26-2010 05:53 PM
A/C questions fmiller GT & SOHC 0 01-13-2002 09:25 AM
