79-85/86 dash harness ground - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 08-13-2011, 04:11 PM Thread Starter
After doing some continuity and resistance tests, it seems that I have a bad ground or poor connection on the dash harness. I always get continuity but on a few items I'll see a resistance of 3.5ohms or so.
I have been able to find one ground with two 16-18ga wires to the right of the throttle pedal bracket, but it heads over to the passenger side kick panel. I would think that there is one closer to the driver's side kick panel. I had the instrument cluster out to see if there was anything to see. No dice other than the one I had previously mentioned.
Everything under the hood has good continuity and good resistance values. Battery terminals are clean and tight.
Much thanks.
5.0LTwiggy is offline
For Sale 89 mass air harness, 89 dash harness and more ias97 Electronics and Entertainment 1 06-26-2011 11:21 PM
For Sale 1996 Mustang Dash Wire Harness (NEW Ford) LX 5.0 Electronics and Entertainment 0 05-11-2011 10:10 AM
Need Help with Under Dash Harness 89GT CDHSTANG Electrical & Wiring 0 04-23-2011 09:11 AM
dash harness supastarrGT 94/95 Tech 1 04-08-2011 06:52 PM
Fox dash harness wiring - premium speaker harness present?? Mustang5L5 General Mustang Tech 4 02-23-2011 02:00 PM
