fuel level sensor - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 08-09-2011, 01:08 AM Thread Starter
mystic_lx's Avatar
fuel level sensor
i have a 89 mustang 5.0 and im gonna drop the fuel tank tommaro to fix the sending unit i belive it has a bad ground wire because when i start the car the guage peggs itself so i was wondering what color the ground wire on the sending unit is or where it grounds out at. thank you in advance any info would be great.
mystic_lx is offline
post #2 of 3 Old 08-10-2011, 12:25 AM
The sending unit ground is a black wire located near the LH backup lamp. The slosh module circuit card behind the instrument cluster can cause the fuel gauge to peg full.
Saleen0679 is offline
post #3 of 3 Old 08-10-2011, 12:30 AM Thread Starter
mystic_lx's Avatar
thats probly what it is. i just spliced in another ground wire right at the sending unit and it dident work
Fuel Gauge on FPR Drops 5lbs when Vac Off ebx 5.0/5.8 Engine Tech 4 06-05-2011 02:13 PM
With correct sized injectors, rails, and pump - do you need an AFPR? ShawnQ 5.0/5.8 Engine Tech 15 01-08-2011 01:56 PM
Lost power on dyno (today) after Bassani X-pipe WITH cats, dyno results attached '00Stang GT & SOHC 32 12-27-2001 05:35 PM
