Trunk release and fuel pump both stopped working on 86GT - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 08-08-2011, 03:58 AM Thread Starter
howie2336's Avatar
I went to start up my 86GT and noticed the fuel pump wouldn't prime. I then went to push the trunk release button and it didn't work either. Are both ran off the same fusible link? The pump, relay and inertia switch are new. Has anyone else encountered this problem?
Second place is the first loser.
howie2336 is offline
post #2 of 4 Old 09-16-2011, 06:20 AM
check voltage
have you check to see if you have 12 volts at fuel pump relay harness should have constant 12 volts at i think the pink wire .
racingrev is offline
post #3 of 4 Old 09-16-2011, 06:31 AM
miss quote
sorry should be the orange with black stripe wire not pink wire i think the pink wire goes to the inert switch then to the pump may want to take ajumper wire from the orange to pink wire and see if the pump run s
post #4 of 4 Old 09-17-2011, 12:18 AM Thread Starter
howie2336's Avatar
Thanks for replying... I'm gonna check those wires and the fusible links tomorrow.
For Sale ➫➫➫ 03/04 Cobra Part out Black & Torch Red ➫➫➫ 2003snake Modular Engine Parts 329 10-09-2011 10:39 AM
