autometer tach problems - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 07-27-2011, 02:59 AM Thread Starter
RTW0223's Avatar
Hey all, not sure if this is the correct place to post this type of question but here goes:
just bought a 5" autometer sport comp 2 tachometer off of someone, and it was previously working when he pulled it off his fox. (keep in mind i also have a 92 fox, while his is an 89) I wired everything up. Wired the red wire into my ignition switch wire. Wired the black wire to a safe ground. White cable to the headlamps switch. Wire the green wire to the tan and yellow ignition coil wire. the tach illuminates, however does not read RPMs at all.
Any ideas?
RTW0223 is offline
post #2 of 4 Old 08-08-2011, 03:28 PM
BlueThunder88's Avatar
I just installed a Monster tach in my fox last nite to replace an older one that had died. First thing I would do is grab a voltmeter/test light and make sure you have power, ground and variable lighting power as you expect. At work so can't remember if the green wire is on the '-' wire for you or not.
1988 5.0 LX Hatch 5-speed
Mustang Dyno Numbers: 244/279
Mustang Dyno Numbers (N20): 335/443
Best ET: 12.72 @111.7
BlueThunder88 is offline
post #3 of 4 Old 08-08-2011, 07:34 PM
ndmus88gteng's Avatar
Trader Feedback: (140)
Any ideas?
Hey I just read the instructions, for a 5.0 on autometers site, they say for the 5.0 engine, hook the tach signal wire to the green wire with the yellow strip on it. that is the neg side, even though we dont have the round coils on our 5.0's.
did you just have the wires crossed, or is it tore up, I hope you got it to work for you.
Rick
ndmus88gteng is offline
post #4 of 4 Old 08-08-2011, 10:35 PM Thread Starter
RTW0223's Avatar
i mightve had them crossed. it was on a fox before mine and it worked perfectly so not sure why it wouldnt work on mine. so i bought a new coil lol
RTW0223 is offline
Help installing an AutoMeter Tach racing01cobra SVT & DOHC 2 07-08-2011 07:00 PM
For Sale Autometer tach 5", water temp 2 5/8", oil pressure 2 5/8", gauge pod cobradvm Electronics and Entertainment 9 06-15-2011 09:02 PM
For Sale Autometer fuel pressure, water temp, tach, and voltmeter red93gthatch Electronics and Entertainment 7 12-11-2010 09:20 PM
need help with autometer tach bouncing around? tofer 5.0/5.8 Engine Tech 1 08-08-2002 12:14 PM
Tach problems with MSD DIS4... kwkcpe GT & SOHC 0 01-07-2002 11:39 AM
