Engine breaking up Problem help request. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 07-20-2011, 07:54 PM Thread Starter
I have a 1993 Mustang LX that we recently finished installing a 306 cuin ford racing engine into. The engine is running but we have a problem with it breaking up under heavy throttle. This is Fuel Injected and we have a new MSD Distributor and coil on it. What's happening is the tach is erratic during the times the engine is mis-firing and we can watch it drop off and bounce around as the engine mis-fires. Some times it runs fine for a brief period of time and then it runs badly again. I haven't gotten too deep into the diagnostic process yet, but I was wondering if this may be a common problem and someone can point me toward a place to begin looking for a bad connection or areas to do voltage checks. Any help would be appreciated, Thanks!
Eagle
Hreagle is offline
post #2 of 5 Old 08-21-2011, 12:00 AM
AJ
What kind of alternator is on it and have you checked the battery voltage and made sure it is fully charged?. MSD systems require a good charging system...battery and alternator. Most 3G alternators use overloads in the circuit . Make sure it's not tripped if installed.
AJ at
87gt,3200# a4 306 w/ported canfields,AFM b4 blower cam, welded & ported GT-40 w/Downs upper,mac long tubes, vortech t-trim 17-19# boost.
60 ft 1.39
best 1/4 mi 9.75 @ 143
best 1/8 mi 6.25 @ 113
AJ is offline
post #3 of 5 Old 08-22-2011, 03:05 PM
91BlueGT's Avatar
you've got a lot of searching to do. i wouldn't just narrow it down to electrical
mech engineer - OKLAHOMA STATE
88 gt hb - 347 all forged, canfield 195cc's, xr282, holley 750, vic jr
89 gt hb - 306, windsor jr's, 70mm turbo, FAST efi, 10pt, vic 5.0, 60lb inj, front wheels off the ground
91BlueGT is offline
post #4 of 5 Old 08-28-2011, 12:43 AM
A bad pip in the distributor would do that
drexelsteve is offline
post #5 of 5 Old 09-23-2011, 02:23 AM
Bingo!! You are most likely loosing a crank signal to the PCM.
93 Twintrbo is offline
Check engine light with 3inch exhaust bwd1973 General Mustang Tech 4 03-27-2011 11:15 PM
Engine will not go into fast idle when started cold, causes? FormerlyBlue88Notch 5.0/5.8 Engine Tech 5 03-10-2011 09:27 AM
Broken Engine Problem found out! quick89gt 5.0/5.8 Engine Tech 4 01-03-2002 05:21 AM
Official Mod Motor 2vna rules Dave King GT & SOHC 37 12-21-2001 01:27 PM
Proposed Modular Shootout Renegade rules (very long!) Modular Performance GT & SOHC 30 12-19-2001 07:30 PM
