bleeding master cylinder - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 07-20-2011, 05:19 PM Thread Starter
how do u bleed the master cylinder without removing it from brake booster on the car. Also, in what order you bleed the brakes. 1993 lx 5.0 THANKS
mustanglx5.0 is offline
post #2 of 3 Old 08-06-2011, 03:20 PM
I'm sure you figured this out by now, but... Both methods require a helper to depress the pedal:
1. Use a bleeding kit (nipples/vinyl tubes) to route the brake fluid back into the reservoir... have helper *GENTLY* pump the pedal until no more air bubbles are seen in the tubing
2. In a pinch (emergency/roadside), you can use your fingers over the ports, just keep the reservoir topped off...
Note: Both methods are messy and brake fluid *WILL* remove paint from wherever it sits for long! Use rags, paper towels, or baby diapers (work VERY well! ) to keep the lines from dribbling on your paint...
'91 Mustang GT 5.0HO/T5/3.27 @ 165K w/ CAI, Bassani X + MAC 2.5" out the back
'88 Jeep XJ 4.0/Longarmed/Locked/Caged/TSLs - FOR SALE!
'72 Jeep "Mossy" Commando AMC304/TBI/TH400/D20/D30/D44/Locked/4.27s/TSLs/Cage/Bumpers/Winch/Corbeau's... for occasional off-road use
Caver Dave is offline
post #3 of 3 Old 08-22-2011, 03:23 PM
Bryan83taco's Avatar
It may sound like more work but just remove the MC and buy the MC bleed kit in the HELP section of your local auto parts store. SO much easier and not as messy. And you won't need to worry about squirting brake fluid on your paint!
Also the MC is at an angle while installed and makes bleeding a pain in the a$$
Bryan83taco is offline
Magical Disappearing Brakes - 1992 Mustang Lifted94XLT General Mustang Tech 84 03-03-2012 01:43 AM
SVO Calipers with stock 93 Master Cylinder and Drums? Need-a-cage General Mustang Tech 8 06-22-2011 10:10 AM
For Sale Strange Master Cylinder # B3360 EIU88GT Suspension 1 04-23-2011 01:49 PM
master cylinder question jkeyz General Mustang Tech 8 03-31-2011 10:45 PM
89 coupe upgrade pbr caliper 93 cobra booster an 95 gt master cylinder! 331lilcoupe General Mustang Tech 35 02-25-2011 10:22 AM
