HELP:: bypass neutral safety switch - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 07-07-2011, 02:06 PM Thread Starter
84GtPony's Avatar
how do you bypass a neutral safety switch?? i got an 84 Gt with a 3350.
84GtPony is offline
post #2 of 2 Old 08-13-2011, 10:40 PM
find the wires on your clutch pedal assembly. unplugg both wires and connect them together. this is dangerous cause the car will move in gear if you accidentally jump the starter relay. I almost got ran over by my 76 camaro doing this! it ran into the garage.
90 coupe, 302,9.7 comp,scat rods, ported windsor sr.'s(286 [email protected]" 2.05/1.60),tfs stage 3 cam,
funnel web, 750dp,c4/4000,4.30 gears, aeromotive 140 pump-motor/holley red for nitrous, 16 gal. cell, 2 stage nitrous,M/T 28x9 et drag,5" cowl hood.
tim harris is offline
Neutral safety switch install FRAN General Mustang Tech 2 06-29-2011 09:45 PM
Neutral Safety Switch? Tech Legal - Drag Strip FiftyMan Drag Racing 3 05-28-2011 12:13 AM
What to do with neutral safety switch in T56 swap? Lt Jake Electrical & Wiring 1 05-24-2011 08:32 PM
Bypass neutral safety switch twbrown44 General Mustang Tech 12 03-06-2011 11:00 PM
T5 reverse light and neutral safety switch wiring CFalvey General Mustang Tech 3 01-14-2011 12:40 AM
