Fuel pump relay - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 07-06-2011, 09:32 PM Thread Starter
sweat90lx's Avatar
Fuel pump relay
I'm wiring up a megasquirt in my car and have everything wired except fuel pump. Going to use the factory relay under the drivers seat.
Anyone have a wiring diagram of it?
Does the ground run to the eec?
12.7s motor, 11.7s spray, turbo 400/460. [email protected]
sweat90lx is offline
post #2 of 5 Old 07-07-2011, 07:25 AM
hope this helps http://www.veryuseful.com/mustang/te...ng_Diagram.gif
86 mustang- tw heads , f cam ,systemax intake, stock bottom end ,procharger p1sc, liberty faceplated tko, team Z rear suspension
noponi2 is offline
post #3 of 5 Old 07-07-2011, 07:33 AM
just blow the picture up, what your looking for is on the bottom right
noponi2 is offline
post #4 of 5 Old 07-07-2011, 01:07 PM Thread Starter
sweat90lx's Avatar
thanks!!
post #5 of 5 Old 07-12-2011, 11:44 PM Thread Starter
sweat90lx's Avatar
just fyi. I had it in my mind that I could use the factory relay and was thinking too hard.
I used a relay from Advance with the factory power wire and wire to pump. Ran my fuel pump wire from the megasquirt and another ground wire.
car drops fuel presure at 5800rpm, need help 98muscrat Superchargers 44 06-15-2011 11:22 AM
Fuel Pump ?'s phillip_w Superchargers 11 04-15-2011 09:33 PM
part nubers, fuel pump relay RICEMAN00 GT & SOHC 3 01-08-2002 10:59 AM
Fuel pump wiring questions NotchDave 5.0/5.8 Engine Tech 0 12-24-2001 01:44 PM
Walbro GSS340 Fuel Pump Install a50sn95 General Mustang Tech 0 12-14-2001 09:06 PM
