Need some coil halp please!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 06-27-2011, 05:52 PM Thread Starter
1bad67sbf's Avatar
I have almost finished building my car but the coil wont fire. it has power to the positive side but nothing on the ground side. when I plug the plug to the coil it allows the pos to feed back out the neg side. "when plugged in and ignition in on position both sides are hot." from what I have seen the pin 4 feeds ground to the coil and module on the front of the coil, right? pin 5 on that module is the other end of the ground circuit and it still reads ground when the coil is saying pos. does this make any sense?
if it maters the computer side is a 92 harness like the car but the injector harness is an 89. I thought they are the same but I could be wrong.
1bad67sbf is offline
For Sale Crane HI6S Ignition box & Crane LX92 Coil jtkz13 Windsor Engine Parts 4 05-25-2011 08:06 PM
For Sale COIL PACK TO COIL ON PLUG conversion harness with boost a spark and all 8 coil ons blckstng96 Modular Engine Parts 5 05-19-2011 01:51 AM
Coil sring rate that is the same as the stock v8 coil spring rate FordFreak300 General Mustang Tech 9 03-06-2011 01:52 AM
Bad Ignition Coil? Stock1991 5.0/5.8 Engine Tech 4 01-19-2011 03:45 PM
New MSD Coil = Noise? hotrodford_88 5.0/5.8 Engine Tech 4 01-13-2002 02:01 PM
