1993 Cobra Mustang Tail Lights and Turn Signal Problems - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 06-26-2011, 01:03 AM Thread Starter
I am running into a problem that I am hoping someone can help me with. I have a 93 Cobra that I just purchased. When I use the turn signals my hazards flash. Does not matter whther I use left or right turn signal hazards blink simultaneously both front and rear. When I look at my dash the turn signals are dull and solid green. I have replaced the flasher behind the dashboard and no changes.
I also have a question on what the cobra tail lights look like when lit. Top row red and yellow are lit. White works only in reverse of course. Bottom row, when pressing brakes the outer portions light up but the rest of the bottom row does not. My question, is it normal for the top row to have the yellow solidly lit and no illumenation from the bottom row?
Any advice is greatly apprecated.
gsoublis is offline
post #2 of 3 Old 06-26-2011, 03:25 AM
5p0intslow's Avatar
The red part below the clear reverse section and amber turn signal section does not light up. if you look closely that is the part of the tailight where the reflectors are.
it sounds like you have an electrical problem with your blinkers but maybe someone else can chime in and help you with this
5p0intslow is offline
post #3 of 3 Old 06-26-2011, 06:44 PM
Check your grounds. All the wires connected to the body with the little green screws. Also make sure you have the right model flash can.
99svt4me2009 is offline
Cobra Tail Lights on 2001 GT serviator GT & SOHC 12 05-14-2011 02:05 PM
Turn Signal Issues 1993 Ford Mustang gsoublis General Mustang Tech 5 04-28-2011 11:04 AM
Turn Signal Issues 1993 Ford Mustang gsoublis Electrical & Wiring 0 04-26-2011 07:44 PM
Wierd Turn signal, High Beam problems Juiced408W General Mustang Tech 6 12-21-2010 03:10 PM
turn on headlights no dash, tail lights? aew93 General Mustang Tech 3 12-24-2001 12:39 AM
