gauge question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 06-10-2011, 01:08 AM Thread Starter
gauge question
Looking to buy 6 piece gauge set. What's the difference between mechanical and electrical? Which one should I go with?
85lxstang is offline
post #2 of 3 Old 06-12-2011, 02:39 AM
Im no expert but my best advice would start with the question are you Carb'd or Fuel Injected?
Since your Pre-87 Im guessing you have a carb, therefore you would most likely require a mechanical gauge since you dont have the proper electronics for the electric gauges..
Good Luck..
goodolboy is offline
post #3 of 3 Old 06-12-2011, 10:23 AM
460capri's Avatar
Trader Feedback: (48)
Go with the electrical gauges the only mechanical one you should use is one for fuel pressure and it needs to be mounted on the out side of the car it can be mounted on the inside but you have to buy the gauge that uses an isolator .
The main difference between electrical and mechanical gauges is electrical uses an sending unit via your wiring or ( wiring you make )to send the info to the gauge a mechanical gauge has fluid sent to the gauge to get the info but if you ever have a leak it will be in the car . Mechanical are a little more accurate but thats all .
Here is a pic of my gauge setup its an old pic but you get the idea .
85 Capri 310 , 10.1cr , solid roller cam 608"/614"x 242*/248* AFR 205 heads , 1 3/4" headers , super victor intake , holley 750DP , MSd ignition system and NOS 150 shot .
460capri is offline
Tags
gauges
Have question about Fuel Pressure Gauge Install.. Thanks 97Saleens281 GT & SOHC 4 01-10-2002 01:02 PM
question about autometer temp gauge KEVIN88GT 5.0/5.8 Engine Tech 6 01-06-2002 11:41 AM
Serious questions dilemma about mechanical oil PSI gauge and DOHC oil PSI readings Cobra Jet NJ GT & SOHC 11 12-14-2001 04:19 PM
Oil Gauge and Sending Unit Question CarlM2 GT & SOHC 4 12-06-2001 09:28 PM
