Oil pres., temp, gas gauges not working - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 06-09-2011, 08:38 PM Thread Starter
GUNRUNINPONY's Avatar
My oil pres , temp and gas gauges are mot working! Oil pres. and temp have no reading, gas gauge stuck at half.
I've unplugged the tank sending unit and checked reading with vohm, it showed to have a reading of full (23ohms) but the gauge stayed on 1/2. Next I pulled the cluster and removed anti-slosh module, gauge then swung to full. I cleaned the contacts on the module and cluster, no change. I then replaced the 100uf-24v capacitor, still reads 1/2 tank. I then checked grounds to instrument cluster wiring, shows to be good. I,m kinda stumped here! I know normally you get either a full or empty reading when thing go bad but 1/2 tank reading?
The oil and temp gauges do have a signal to them but its commanding a minimum reading for both! WTF?
So where do I go from here? I'm ass-u-ming that the antislosh wont cause all of this, am I wrong?
Please feel free to give any input, good or bad. I'm usually pretty good with wiring, but that does not meant I don't have my head up my ass on this one!
A wise man once said "It's better to remain silent and appear ignorant, rather than speak and remove doubt!
91 GT, TT 306,TFS 170's, Track Heat,60lb inj, 150 shot, 3.27's, setting up for nice dd with Maximum Motorsport suspension.
GUNRUNINPONY is offline
Want To Buy WTB: Autometer phantom gauges (fuel pressure and trans temp) six6six Electronics and Entertainment 1 04-27-2011 12:45 AM
Anyone going to start working from home due to the high gas prices? nobody special Lounge 21 03-14-2011 12:12 PM
What thread sealer for water senser and oil sender (installing gauges)? 92Pony 5.0/5.8 Engine Tech 4 12-28-2001 01:25 PM
Serious questions dilemma about mechanical oil PSI gauge and DOHC oil PSI readings Cobra Jet NJ GT & SOHC 11 12-14-2001 04:19 PM
gas in the oil? RANGER 302 5.0/5.8 Engine Tech 2 11-26-2001 07:01 AM
