ignition switch HELP - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 06-07-2011, 07:05 PM Thread Starter
ok so i have a 92 LX and for the last few weeks for my turn signals and ac to work i would have to cut the car off and turn the key back to the on pos and pop the clutch it would work fine after that. that trick stopped working yesterday so i bought a new ignition switch.....well during the install of that the whole Electrical connector fell out of the bottom of the ignition with the harness still attached...... another piece also fell out with it that i guess is what moves when you turn the key forward and backward to make the proper connections. is this thing done? if not how does this contraption go back together. obviously the car has left me in a pickle had to bum a ride from co worker.
thanks
Stop posting GT40 intakes when they are Explorer intakes
302KILU is offline
post #2 of 4 Old 06-08-2011, 03:03 PM
thanks
That piece is done. I had the same thing happen before. There are spring loaded ball bearings that fly out when it separates. If you can find all of the pieces you can try to reassemble it and then zip tie it up tight to the column. I'd just get a new one though (and still zip tie it).
What you have is a new ignition cylinder. What you need is a new ignition switch. They're $10 to $20.
Google
Megasquirt
seijirou is offline
post #3 of 4 Old 06-08-2011, 08:57 PM Thread Starter
thanks for the reply i got it all figured out today. sourcing the part was the only speed bump
302KILU is offline
post #4 of 4 Old 06-09-2011, 12:17 PM
cool man glad you got it figured out.
Megasquirt
seijirou is offline
Something let go in my ignition switch MoonlightBlue96 General Mustang Tech 4 06-09-2011 07:36 AM
removed alarm wont crank with ignition switch please help ASAP strattonc Electrical & Wiring 2 04-08-2011 09:51 PM
replace lock cylinder or ignition switch ? Need help. pwr4all3 General Mustang Tech 1 02-07-2011 07:46 AM
Ignition Switch ? Quick Stallion General Mustang Tech 8 11-16-2010 06:14 PM
