need help wiring up aftermarket fan - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 06-07-2011, 11:14 AM Thread Starter
Trader Feedback: (21)
I have an aftermarket dual fan setup, it only has two wires running from it a power and a ground, I think my module that controls the fan is busted, so I want to wire it up seperately. I thought about running a simple power from the battery with a toggle switch, but I heard you can get inline fuses and a thermostat controller that you can wire in, I really dont know much about wiring stuff, so any info/ pictures are appreciated.
thanks, Mike
94svtcobraftw is offline
post #2 of 2 Old 06-07-2011, 01:49 PM
I've used one of these with decent success.
Flex-a-lite 31147 - Flex-a-lite Adjustable Electric Fan Controllers - Overview - SummitRacing.com
It uses a probe that pushes through the fins of your radiator to pick up the temp. There is a dial on the body of the controller (which is just a heat-activated switch) so you can dial in what temperature you want the fan to come on.
The best way to wire up power to the fan is through a relay.
Here's a site with some pretty clear instructions on how to hook up a relay with pictures. The "on off" switch in the picture represents your ignition switch.
Jeep Electrical - Automotive Relay Basics - Learn "How-To" Control Lighting.
The only variation is that you wire the controller between pole 85 of the relay and ground.
You can see in the pictures where the fuses go. You can buy in-line fuse holders as well as automotive relays from radio shack. Use a 3 amp fuse as the switch fuse.
For the relay use one rated above whatever amps your fan is rated for, and use a fuse one size up from whatever your fan is rated for.
This page has a chart for wire gauge (size) and how many amps it can handle. You want to look at the Maximum Amps for Power Transmission column. Whatever amp fuse you choose, go at least 1 size up from that for the wire. Also make sure you use stranded wire, not solid wire.
http://www.powerstream.com/Wire_Size.htm
Megasquirt
seijirou is offline
Why yes, it IS another Taurus Fan Install Post MFE General Mustang Tech 73 07-09-2018 11:50 AM
wiring an aftermarket fan to come on with a/c stangly04 94/95 Tech 2 04-04-2011 07:25 PM
03 fan wiring diagram palacios289 SVT & DOHC 7 12-01-2010 01:51 PM
Proposed Modular Shootout Renegade rules (very long!) Modular Performance GT & SOHC 30 12-19-2001 07:30 PM
