mass air wire colors need help fox code 66 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 06-06-2011, 10:02 PM Thread Starter
ias97's Avatar
Trader Feedback: (61)
I keep pulling a code 66 on my 90 fox , I suspected a bad meter so I pulled it and used a known good meter, both are pro m 77 for 42's, now after clearing the codes then with the new meter same thing, and it only happens after driving. so I started to look at the wiring, and I realize someone had spliced it, now there is a yellowish and a bluish wire I think they have them reversed?? is this possible? I see the red and black are correct the harness was extended and the plug wasnt the original plug, there is red , black blue and brown on the plug, like I said red and black are good, any help would be great
ias97 is offline
For Sale 88 Mustang 5.0 Mass Air Wiring Harness,8LD Computer HaulinAssMaro Electronics and Entertainment 1 04-11-2011 03:44 PM
For Sale proM 77mm maf mass air meter 42# fox supercharged pkstang Electronics and Entertainment 1 01-25-2011 05:01 PM
For Sale throttle body,carb,fuel pump and mass air meter nasty 91 Fuel System & Related 10 01-02-2011 09:27 PM
anyone using 4.6 cobra 80mm mass air meter in their fox pkstang 5.0/5.8 Engine Tech 2 11-26-2001 11:05 AM
