Steering Wheel Wiring - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 05-31-2011, 09:06 AM Thread Starter
1BAD6T6's Avatar
I have my dash broken down and I'm getting ready to wire up my transbrake/2step circuit. I want to use the right side horn button as the trigger. I've used veryuseful.com's schematics, but it doesn't address the steering wheel itself. Can anyone which wires at the steering column are the horn wires I'm looking for?
Shaun
1966 Mustang Coupe
1993 Coupe - LM7, pt88, th400, MS3x
1995 GT - 100% Stock (emissions and all)
1BAD6T6 is offline
post #2 of 2 Old 06-07-2011, 02:01 PM
The buttons on the steering wheel connect to the wires in the column through a copper collar that's fixed to the column. Then metal contacts connected to the wheel drag along this copper collar. The horn buttons are only on individual wires at the wheel. They join together to a single contact touching that copper collar... So you can't just tap in to the right-side horn button through wires in the column, you'd need to separate the right from the left in the steering wheel first, and then tap in at the steering wheel itself.
This causes the problem of your wires wrapping up around the steering column as you turn the wheel. That's the problem the engineers solved with the collar and sliding contacts.
If you want your trans brake button to be on your steering wheel you either need to add an additional collar and sliding contact somehow, or re-purpose one of the existing ones, or add a transmitter or something so you can transfer the signal wirelessly.
Megasquirt
seijirou is offline
For Sale Grant 773 Steering Wheel + Install Kit DJG Interior Parts 4 04-19-2011 09:33 PM
2012 steering wheel amplifier28 S-197 Mustang GT (2011-2014) 7 03-20-2011 08:50 PM
MoMo Steering wheel racing01cobra Road Racing/Auto X 5 01-11-2011 04:27 PM
Steering wheel noise BadAndy S-197 Mustang (2005-2010) 0 01-05-2011 08:36 AM
How do I change steering wheel w/ airbag with out breaking my nose? tilt steering robertwigton General Mustang Tech 11 12-06-2001 08:26 AM
