Help Identifying Connectors on 1986 Mustang (Pics Included) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 05-31-2011, 12:40 AM Thread Starter
I am hoping you guys can help me identify some connectors. At the end of the driver side/headlight harness there are some pretty heavy wires coming off the passenger headlight harness area.
One of them is a small white 3 pin connector with 2 wires. One wire is yel/wht and the other is GRN/R? hard for me to tell cause I am color blind. The yellow/white wire traces back to an 18GA fuseable link straight to the starter solenoid. The GRN/Red wire goes to a 20GA fuseable link near the wiper motor connector area and stops there.
Another plug is a wide flat 3 pin plug looks kind of like the coil plug but a little biger, has 2 large wires going to it. Both are black with two yellow stripes and trace back to main fuesable link going to the starter relay.
Third plug is a single pin with a big yellow wire going to it, and going straight back to a 16GA fuseable link on the firewall.
Can anyone tell me what each one plugs into or where it goes? Thanks!
Dman03GT is offline
post #2 of 5 Old 05-31-2011, 01:09 AM Thread Starter
I've got the two three pin plugs figured out as alternator plugs. Anyone know what the big yellow single pin goes to?
Dman03GT is offline
post #3 of 5 Old 07-08-2011, 02:58 PM
fiore1230's Avatar
looks like alternator regulator wiring.
dave
93 White Notch
5 Lug 4 Wheel Disc
fiore1230 is offline
post #4 of 5 Old 08-18-2011, 10:24 AM
I know this is an older thread, as like stated above all of those wires are for the older 1g type alternator. The other half of the harness that you can see in the last picture are for the headlights. Ditch all these wires back to where they originate, and wire for the 3g alternator.. As I see you might be using for the mod motor swap. Been there done this!
~Republic of Texas~
~Silver Foxbody w/ Fordstrokers 363~
Fast82LX is offline
post #5 of 5 Old 08-18-2011, 07:24 PM Thread Starter
Yep it's an older thread but maybe it'll help someone else in the future, after I figured out what they were I ended up using the wiring for other acessories since the alternator was already wired up with my swap.
Dman03GT is offline
Junkyard Horsepower SUMMARY! slo5oh 5.0/5.8 Engine Tech 231 01-30-2015 11:35 PM
Please post white FOX3 Mustang PICS Phils88gt The Body Shop 29 02-21-2002 02:52 PM
Pics from NC Mustang Alliance's Dec. meeting GeoSnake Southeast 4 01-01-2002 11:35 AM
1986 Ford Mustang Tommy Six Shooter 10 12-13-2001 12:44 AM
