Explorer EDIS/89 5L A9L - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 05-30-2011, 01:07 PM Thread Starter
Was wondering if I could get some direction/help.
Is it possible to Adapt the EDIS Ignition System used on the 5.0L GT40(96&Up)style an 89 5.0L using an A9L Computer.I bought an early 97 5.0L
Explorer Engine with the GT40 Heads and Intake,I was looking at it and
wondering If I could put the motor in my 89 5.0L Shell?Since it uses a
crank trgger,ignition module and cam position sensor I got to wondering if
anyone had experience or could help me out in wiring using an A9L ECM
if its even possible?Input would be greatly appreciated!
Nice86gt is offline
post #2 of 6 Old 05-30-2011, 03:57 PM
Yes it is possible. All you need is a way to turn on the DIS in the EEC, i.e. a QuarterHorse, or any other tuner that can manipulate the scalar.
I've got the parts, but haven't done it yet. There are a couple guys over on eectuning.org that have done it, and one guy did it with a 351C in a Pantera.
junior73 is offline
post #3 of 6 Old 05-30-2011, 07:18 PM Thread Starter
Thanks for the help!
Nice86gt is offline
post #4 of 6 Old 06-08-2011, 01:34 AM
Indo-Canuck-Yankee
Shaker666's Avatar
I'm from eectuning.org and have done it to an A9L that controls the 400M motor in my '79 Bronco. The harness modification wasn't tough, but do your homework on the schematics. I used a '93 Lincoln as the donor for coil packs and EDIS8 module. You should be able to use the '97 Explorer cam sensor directly. This is an EXCELLENT upgrade to any engine.
'71 Mach 1: totaled - R.I.P.
Shaker666 is offline
post #5 of 6 Old 06-19-2011, 09:54 AM
indy2000's Avatar
yeah that was an easy swap?????
indy2000 is offline
post #6 of 6 Old 06-19-2011, 12:16 PM
Indo-Canuck-Yankee
Shaker666's Avatar
Hehe... we did the entire conversion in 2 weeks flat. The biggest issue I found was the crank trigger sensor mounting (which you did for me) and the fuel filters clogging up!
Want To Buy Explorer 5.0 Powerdyne kit SVOJOE Power Adders 10 10-05-2012 07:35 PM
Explorer throttle body mods? AlanGT350 5.0/5.8 Engine Tech 6 04-18-2011 11:23 AM
For Sale FS: 2004 Ford Explorer 4.6L V8 customized JarvisB Other Fords and Trades 1 02-16-2011 11:12 AM
For Sale FS: 2004 Ford Explorer 4.6L V8 customized JarvisB Mustangs For Sale/Wanted, 1999-2004 4 01-25-2011 12:41 AM
Modifying '99 Explorer 65mm TB to work on Mustang Mustang5L5 5.0/5.8 Engine Tech 5 05-25-2002 08:36 PM
