Question About Wiring On Starter Solenoid - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 05-26-2011, 09:46 PM Thread Starter
The small wire that goes on the small lug in the center that has a rubber 90* boot over it.... is that the signal wire that goes hot when you turn the key? If a person was wanting to eliminate the fender mounted solenoid there could you just extend that wire down to the signal lug on a starter mounted solenoid?
Appreciate the help.
Also over by my fender solenoid I have a 1 pin connector with two BLK/WHT wires going to it, can anyone tell me where that plugs into?
Thanks!
Dman03GT is offline
post #2 of 3 Old 05-27-2011, 12:14 PM
Warlock1's Avatar
Trader Feedback: (23)
To answer your question, yes it is the trigger wire for your starter solenoid. Why do you want to eliminate the solenoid??
Warlock1 is offline
post #3 of 3 Old 05-27-2011, 10:46 PM Thread Starter
I've got it figured out I think, but thanks for the reply! The solenoid is going away because of an engine swap, the starter for the new engine has a solenoid already on it and that fended mounted deal is just an eye sore at this point.
In fact I think I am going to tuck that entire harness away into the fender.
Dman03GT is offline
Has anyone with a mini starter replaced their stock solenoid w/ a relay? raceoholic330 General Mustang Tech 9 09-06-2011 05:19 PM
02 GT starter wiring stupidslow02gt GT & SOHC 2 05-03-2011 03:54 PM
Wiring in fenders, where to mount solenoid Bob Knudsen General Mustang Tech 2 01-23-2011 08:46 PM
Help Please! Melted starter wiring harness. jkrahn 5.0/5.8 Engine Tech 3 12-23-2010 01:41 PM
Quick mini starter wiring question.... Trentk 5.0/5.8 Engine Tech 4 12-03-2001 11:59 AM
