What to do with neutral safety switch in T56 swap? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 05-24-2011, 08:28 PM Thread Starter
Lt Jake's Avatar
Not sure what to do with the neutral safety switch from the chassis to the swapped in T56 (which does not have one). I understand that the neutral safety function is only for diagnostic testing. How do I avoid the Code 67 and Service Engine lights with a T56 into a fox body swap?
'03 Black Blown Eaton Marauder
'78 Scout II
Lt Jake is offline
post #2 of 2 Old 05-24-2011, 08:32 PM
88redcoupe's Avatar
Put it in Loop..
88redcoupe is offline
Want To Buy tremec 3550 neutral safety switch blwn89hatch Drivetrain Parts 0 03-14-2011 01:30 AM
Bypass neutral safety switch twbrown44 General Mustang Tech 12 03-06-2011 11:00 PM
Clutch safety switch, adding push button switch into it.... black93 General Mustang Tech 2 01-30-2011 12:10 AM
T5 reverse light and neutral safety switch wiring CFalvey General Mustang Tech 3 01-14-2011 12:40 AM
AOD transmission to manual swap - Neutral saftey switch not working - how to fix? rednotch General Mustang Tech 2 01-07-2002 02:31 PM
