Red/Green wire from solenoid 90 Fox - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 05-12-2011, 05:08 PM Thread Starter
Where does it go to from the solenoid? I dont see it on the plug into the ign switch or any where on the fuse box.
Thanks.
DonDDR1 is offline
post #2 of 6 Old 05-13-2011, 07:20 AM
cda97's Avatar
Thanks.
Are you talking about the starter relay (solenoid)? It should be a red wire with light blue stripe which might appear green. I have the 1990 wiring diagram manual to help you out.
1990GT- New suspension, 5 lug Cobra disk brakes, King
Cobra clutch, FRPP 7003Z T5, aluminum drive
shaft and 3:55 gear. Daily driver with 200K plus
miles.
cda97 is offline
post #3 of 6 Old 05-13-2011, 03:44 PM Thread Starter
I am installing a OEM Ford alarm system and their manual calls it red/green. I found it goes to the switch on the clutch.
DonDDR1 is offline
post #4 of 6 Old 05-14-2011, 03:41 AM
cda97's Avatar
Is your problem resolved?
miles.
cda97 is offline
post #5 of 6 Old 05-15-2011, 04:59 PM Thread Starter
That one is. Now I have to get access to the orange/white that runs from one lock solenoid to the other buried under the dash. I ordered that book from Amazon. Thanks for your replies Bro.
DonDDR1 is offline
post #6 of 6 Old 05-15-2011, 07:07 PM
ashleyroachclip's Avatar
Good to see another member from Oregon...
ashleyroachclip is offline
Possible to wire Mach 460 in fox without amps. Mustang5L5 Audio 6 01-25-2011 07:54 PM
How exactly do I wire keyless entry 1987 Fox. Speedy911 General Mustang Tech 4 01-17-2011 10:11 AM
Testing Circuits, How Can I Wire Solenoid Just for Key On Power? lakecityg General Mustang Tech 11 01-10-2011 03:57 PM
Electrical guys: What is the Yellow wire that goes from fender solenoid to firewall? mustangmisfit 5.0/5.8 Engine Tech 8 12-24-2001 12:13 AM
