Brake pedal switch installation/wiring - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 05-11-2011, 02:34 PM Thread Starter
eggens's Avatar
I've had issues with my brake lights ever since I did my 5-speed swap in my '85 convertible, and I'm wondering if I just have the dang switch installed wrong.
Right now, it's hanging from the arm that the brake pedal and clutch pivot on, next to the brake pedal. It doesn't appear to be fastened onto the pedal in any way. My problem is that it changes orientation relative to the brake pedal, which results in no brake lights or having them always on. I'm wondering if it's supposed to be fastened or connected so that it moves with the pedal.
If I zip-tie it to the pedal, it works better, but I tend to periodically get brake lights when I'm not on the pedal.
I looked at a buddy's '90 Automatic, and his appears to be fastened to the pedal at a different angle and more securely than mine.
What am I missing?
Rebuilding an '85 convertible. Was a 3.8 C5 auto, now 5.0HO EFI w/GT40 top end, WCT5, 8.8 w/3.55's, MAF Upgrade, electric fan, upgraded brakes, all new exhaust, suspension, stereo, interior, paint, rims and tires. It's a work in progress, but REALLY fun to drive.
eggens is offline
post #2 of 3 Old 06-11-2011, 03:55 PM
onyxblue 97's Avatar
It's kind of tricky in the position it has to maintain to work properly.
There is a small plastic bracket that wraps around the pedal its held in place by the pin on the top of the pedal.
In turn this plastic bracket ...more of a plastic wraparound clip holds the switch in the proper position.
onyxblue 97 is offline
post #3 of 3 Old 06-11-2011, 03:55 PM
I'll see if i can get you a picture.
fox rear disc brakes?? phillie356 General Mustang Tech 64 10-14-2012 08:49 AM
Magical Disappearing Brakes - 1992 Mustang Lifted94XLT General Mustang Tech 84 03-03-2012 01:43 AM
For Sale Hawk Brake Pads FREE SHIPPING [email protected] Suspension 6 12-02-2011 12:35 PM
NEED HELP w/ brake light switch on brake pedal assembly???? The Man 5.0/5.8 Engine Tech 2 12-16-2001 04:31 AM
How much higher should clutch pedal be above brake pedal??? olbob GT & SOHC 1 12-01-2001 01:22 PM
