3G output voltage, whats acceptable - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 04-29-2011, 11:13 PM Thread Starter
Eleanor68's Avatar
Trader Feedback: (18)
I have read and understand the voltage output will drop as the temperature increases. My question is will/should the output voltage stay at around 14.4 volts when running-no load, and is a dvm reading of around 14.6-14.7 too high at start up, or would this be considered within range., Once the black magic fan kicks on, the voltage drops to around 13.2-13.7 volts idling, but didnt seem to increase the voltage when I raised engine speed.
any thoughts ??
68 Mustang FB, Eleanor body kit, pepper gray, TCI full chassis frame cradle, 9 inch w 3 link, torque arm, panhard bar, coil overs, wildwood brakes. 427 dart CHI 3v heads, intake
Eleanor68 is offline
post #2 of 3 Old 05-05-2011, 12:21 PM
You're good. as long as it doesn't spike up over 15 or so, and as long as it doesn't drop down into the low 12's. 13.5 to 14.7 is a fine range. mine does the same thing by the way. also, where are you measuring the voltage at?
T-rex80 is offline
post #3 of 3 Old 05-09-2011, 07:37 AM Thread Starter
Eleanor68's Avatar
i measure both at the alternator, and starter relay, as well as the back of the main inline fuse...all to solid ground reference, and back of the alternator....
When checking voltage, does your TPS do this? Jack Straw 5.0/5.8 Engine Tech 2 01-09-2002 09:15 PM
How do I measure alternator output? and does it affect fuel pump if volts are low? rigged94 Electrical & Wiring 4 01-04-2002 04:07 PM
tps voltage question 86style 5.0/5.8 Engine Tech 8 12-28-2001 08:25 PM
Lost power on dyno (today) after Bassani X-pipe WITH cats, dyno results attached '00Stang GT & SOHC 32 12-27-2001 05:35 PM
IMRC Voltage BlackHawk GT & SOHC 2 12-04-2001 06:11 PM
