dual fans wiring - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 04-29-2011, 07:30 PM Thread Starter
justin89tt's Avatar
dual fans wiring
i just wired up a contour style dual elec fan using a dual fan control wiring kit from autozone, as soon as i turn key on,the fans start up. i followed directions,it was very simple.should they not run until the probe gets to a certain temp? this is how i wired it:
red- direct to battery(inline fuse)
orange- + fan
blue +fan
black ground
yellow to switched power. i tied the yellow to a red with green stripe that went to my ignition. its the wire that goes into the MSD then the MSD goes to coil. is it possible that the probe has an internal short and causeing it to constantly run when power is turned on?
any help is appriciated. thank you
justin89tt is offline
post #2 of 4 Old 05-04-2011, 05:46 PM
Fans should not turn on until the probe heats up. Might want to draw up a diagram that shows which pins go where. The colors of the wires don't really provide any info.
bgoins is offline
post #3 of 4 Old 05-05-2011, 06:08 AM
Here is how I wired my contour fan. Only thing different from the schematic is that instead of grounding to the body I went to the negative battery terminal. Used a cheap flexalite fan controller and a 5 pin relay. Upgraded alternator. Everything works as it should. No issues.
Hope this helps.
bgoins is offline
post #4 of 4 Old 05-05-2011, 12:54 PM
mhinchley's Avatar
Trader Feedback: (44)
Here is a diagram that is easy to understand. https://www.bajadesigns.com/2005%20W...20-%20Auto.pdf
03 Whippled E85 Cobra Vert & 00 ZX12R
4r70w swap in progress 9-1-14
mhinchley is offline
For Sale Saleen Dual Electric Fans procharged91stang Miscellaneous Mustang Parts 7 07-26-2011 08:47 PM
Changing the hatch wiring from 1989 to 1992 sozzyber General Mustang Tech 3 04-24-2011 09:32 PM
Suggestions, wiring aftermarket fans screamin gt GT & SOHC 14 03-31-2011 07:31 AM
For Sale Racing Oil Cooler With Dual Electric Fans TorkMonster Modular Engine Parts 7 03-15-2011 10:24 PM
What company actually makes the MK8 and Taurus fans? Wiring questions. Nitrous SSC General Mustang Tech 9 12-14-2010 05:56 PM
