SN95 without factory keyless - alarm install - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 04-27-2011, 12:37 AM Thread Starter
BLiND's Avatar
I am installing a Viper 350 responder 2-way alarm into my 1997 mustang. I have most functions working fine, but I'm having trouble getting the door trigger to set the alarm off, and make the trunk pop work.
I have the wiring guides from the12volt and have tied into the dome light wire (black + blue stripe) in the drivers kick panel, I verified this wire gets power when the dome light is on...but I can lock with the alarm, unlock with the key, open the door and the alarm wont go off?
Also I wired in a relay to the trunk pop switch, and tapped into the wire (purple + yellow stripe) at the drivers kick but holding the aux on the remote wont pop the trunk open...?
Guides I've referenced -
http://www.the12volt.com/installbay/...etail/894.html
http://www.bulldogsecurity.com/diagr...8&link=Bulldog
this isn't the first alarm I've installed.
1989 Notchback LX H/C/I/5.0/T5/5 lug/10psi/Etc - ex 2.3L/A4LD
2002 F150 Harley-Davidson 5.4L/4R100 - Stiegemier Stage 4
BLiND is offline
MY sn95 rear seat install pics throthaduece85 The Body Shop 0 02-10-2011 10:01 PM
96 GT Factory Keyless Entry??? Animal General Mustang Tech 2 01-11-2011 08:08 AM
SN95 alt install question on Fox3 wht92lx 5.0/5.8 Engine Tech 6 12-06-2001 05:01 PM
Factory / Dealer installed alarm -- help 1994 1995 CanGT Electrical & Wiring 0 11-24-2001 10:56 PM
