any tips on how to disconnect stubborn connectors - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 04-23-2011, 09:12 PM Thread Starter
pkstang's Avatar
Trader Feedback: (162)
Angry any tips on how to disconnect stubborn connectors
I’m cleaning up some wiring around the cage and can’t disconnect some big connectors that are located on the driver’s side foot well and don’t wanna damage them…
pkstang is offline
post #2 of 3 Old 04-23-2011, 09:26 PM
Rich G's Avatar
Trader Feedback: (35)
Penetrating oil
Rich G is offline
post #3 of 3 Old 05-05-2011, 12:27 PM
also you could make some small wedges out or plastic so you can lift the tab up only as high as it needs to go. that way you can get a good grip on the connectors and pull them apart. some lube in there helps. I always just take my time wiggling them until they break free and go from there. just don't pull on the wires at all, bad things happen then.
T-rex80 is offline
What are these connectors? Any guesses?? GDDYUP2 Electrical & Wiring 7 06-29-2015 10:33 AM
carb conversion redfox89 5.0/5.8 Engine Tech 6 11-11-2013 09:20 AM
Torque box and SubFrame Connectors welding StriderTacticaL General Mustang Tech 4 12-27-2010 04:23 PM
passenger side airbag disconnect streetsnake94 General Mustang Tech 2 12-07-2001 03:36 PM
Any tips on putting new carpet in? marty The Body Shop 2 12-06-2001 11:02 AM
