foxbody lc-1 wiring...anyone have a write-up or anything? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 04-19-2011, 09:09 PM Thread Starter
killer5-0's Avatar
Trader Feedback: (28)
i have the 02 sensor coming out from a grommet under the drivers seat...wires run up to the drivers kick panel...i want to tie everything in right there if possible but i have a few questions.
what lines are you guys tapping into?
what are the two black plugs that come off the controller and where do i put them?
i built a pod so my gauge can mount on my door...i routed the gauge wire through the door loom so i need the wiring to be around the drivers kick panel.
do i leave my stock 02 sensors in?
killer5-0 is offline
post #2 of 4 Old 04-23-2011, 09:09 PM
pkstang's Avatar
Trader Feedback: (162)
have you tried reading the instructions...???
http://www.innovatemotorsports.com/s...C-1_Manual.pdf
pkstang is offline
post #3 of 4 Old 04-29-2011, 06:49 PM Thread Starter
killer5-0's Avatar
yes i did...was looking for what factory wires they spliced into...doesn't say that in the instructions....
post #4 of 4 Old 05-13-2011, 12:24 PM
What EEC are you using? If stock then you need to leave the stock O2 sensors in.
I use to run a megasquirt with the LC-1. I had wired the stuff going to the ecu through the stock O2 wiring. I took an old O2 sensor and cut of the plug. Then wired the LC-1 into that. You should be able to get power, ground, heater, and signal.
I did it this was so I could easily switch back to the stock EEC if need be, like I've now done. Its been awhile since I did and removed the LC-1, so I am trying to work off memory.
5_0Muscle is offline
For Sale 100's of foxbody and 94-98 parts mygreengt Exterior Parts 29 01-24-2013 08:36 PM
For Sale 100's of foxbody and 94-98 parts mygreengt Interior Parts 48 06-22-2012 02:17 AM
For Sale 100;s of misc items for foxbody and sn95..cleaning house mygreengt Miscellaneous Mustang Parts 13 04-23-2011 10:40 PM
Automotive wiring literature? 5.0calypso93lx AEM EMS 4 04-19-2011 07:44 AM
wiring diagram for window switches on a foxbody?...need to pull power for my LC-1... killer5-0 General Mustang Tech 2 04-18-2011 07:36 PM
