Cheaper Fox Alternator Upgrade? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 04-07-2011, 12:21 AM Thread Starter
What are the alternatives to buying a PA or Powermaster High Output alternator for my 91GT? I've heard that a 94/95 alternator will work, but what else do I need?
snakedoc257 is offline
post #2 of 9 Old 04-09-2011, 05:03 PM
late taurus 130 amp alt will bolt on after enlarging top mounting hole. use the harness from the taurus, everything bolts to starter solenoid. I get them at local pull yourself yards here for $18-20 bucks
90 coupe, 302,9.7 comp,scat rods, ported windsor sr.'s(286 [email protected]" 2.05/1.60),tfs stage 3 cam,
funnel web, 750dp,c4/4000,4.30 gears, aeromotive 140 pump-motor/holley red for nitrous, 16 gal. cell, 2 stage nitrous,M/T 28x9 et drag,5" cowl hood.
tim harris is offline
post #3 of 9 Old 04-18-2011, 08:18 PM
ptmccray's Avatar
Originally Posted by tim harris View Post
late tarus 130 amp alt will bolt on after enlarging mounting top hole. use the harness from the taurus, everything bolts to starter solenoid. I get them at local pull yourself yards here for $18-20 bucks
what year tarus can u get these from?
87 gt vert stock motor,355 gears ,5 lung conversion,17 cobra r,5 speed
ptmccray is offline
post #4 of 9 Old 05-18-2011, 12:32 AM
late 90's well into the 2000's.
post #5 of 9 Old 05-19-2011, 10:49 AM
straightliner1's Avatar
I've done this swap once already myself.
Read this:
The Corral Tech
The easiest route to happiness is a trip to your local junk yard. Scout out a 94-95 LX/GT alternator, a stator plug, the alternator plug and approximately 6 feet of 8 gauge power wire.
Here's the stator plug, which can be found on the car, or also new from a number of sources.
1994-04 Mustang Stator Plug by PA Performance at LRS - Same Day Shipping!
Also, here's the alternator plug itself, also available form the donor car or secondhand:
http://www.paperformance.com/scripts...p?idproduct=55
The size of the alternator itself will fit onto the stock Fox bracket. You will have to notch the inside of the bracket which is made easy with the use of a die grinder or a dremel with a small cutoff wheel.
Best of luck, it's a great mod and you'll be happy with the results!
Justin
straightliner1 is offline
post #6 of 9 Old 05-19-2011, 11:08 PM
same alt on a taurus. ford uses it on lots of models.
post #7 of 9 Old 05-19-2011, 11:25 PM
Sir Loin of Beef
What about the alt off a 94-95 v6? Aren't they the same?
Doc_G is offline
post #8 of 9 Old 05-26-2011, 04:45 PM
yes. 89 up t-birds have em too, most post 89' Fords(other than mustangs) have higher amp alternators. most cars with electric fans have 100+ amp alternators
post #9 of 9 Old 08-14-2011, 07:32 PM Thread Starter
Wiring pictures
Could someone post some pictures of the wiring on the back of the alternator. Both my stock plugs have a white wire with a black stripe. I know one of them is the stator wire.
I have a new stator wire plug, and I have the alternator. Now I just need to figure out where to get a 4G wire to go from the post to the solenoid.
Once I cut the Black wires with the orange stripe, do they both get ring terminals and connected to the alternator post?
Thanks again, sorry I know this topic has been beat to death.
For Sale Misc fox and sn parts johnson93gt Miscellaneous Mustang Parts 8 03-16-2011 07:02 PM
How well can a Fox Body handle??????? Stangposse Road Racing/Auto X 23 03-16-2011 01:54 PM
Want To Buy WANTED: SN95 to Fox Throttle conversion parts 94_cobRa Miscellaneous Mustang Parts 0 01-12-2011 06:54 PM
Rockefeller wants to silense FOX and MSNBC? JohnC76 Politics 21 11-22-2010 04:18 PM
Lou Dobbs moves to Fox r.barn Politics 3 11-12-2010 07:22 PM
