Mustang won't stop turning over!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 04-01-2011, 11:15 PM Thread Starter
Car continues to turn over and tries to start even with the key out of the ignition
Hey, this isn't the first time that I've ran into this problem with the same car. In fact it is the fourth! So the third time it happened, ire placed everything I thought that it could be, battery ground wire, put new solenoids on it...on both the starter and engine bay. Also I replaced the starter. Also, I forgot what this tested but I remember doing it the second time: on the engine bay solenoid while the car kept trying to turn over, I took the one wire off with the boot that goes right over the bolt. And it continued to try to turn over. And since the third time, it's lasted a really long time. But then did it again. So since I replaced everything about a month or 2 ago, I'm quite sure I can rule those problems out. Any help is appreciated thanks.
90lxhatch93 is offline
post #2 of 2 Old 04-02-2011, 06:05 PM
I went through two NAPA fender-mount solenoids about a month apart that did this same thing. I purchased an OE solenoid from Ford(Cost as much as the two napa units that crapped out) and haven't had a problem since.
As long as the main(large) wire for the starter has to go through the fender solenoid, then that is the problem, unless the small terminals are getting power with the key off, then it could be your ignition switch.
Hope that helps!
1983 Ford Thunderbird: '03 Stang V6 carb conversion, 3.73's w/ Trac-Loc, electric fan, 3G upgrade, AC Delete, 5 Lug conversion on 18"s. 5-Speed Install complete!
1993 F-350 1 Ton Diesel 4x4. Standard Cab/Long Bed on 33's.
"Fat Girls Welcome, It's A One Ton"
jrad235 is offline
Tags
doesn't stop turning over, stuck turning over, won't stop turning over
Mustang stuck turning over 90lxhatch93 EEC Tech 7 02-11-2011 03:04 PM
