gauge wiring help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 03-31-2011, 06:52 PM Thread Starter
gauge wiring help
ok here goes, i'm installing a Fuel Lever , and Electric Oil Pressure gauges in my car. it's a 90 Mustang GT.
Now from the Fuel gauge i ran Grnd terminal to Grnd, Ignition Terminal to Red wire/ Light Green Stripe ( behind speedo Gauges ) , and the Sender Terminal to the Yellow/White Stripe wire ( behind speedo ) and get nothing. checked ground it's perfect.
Now the Oil pressure gauge i ran Grnd terminal to Grnd, Ignition Terminal to Red Wire/ Light Green ( like above ), and the Sender wire to the new Sending unit i installed, again nothing.... please help a brother out. thanks
shiz1125 is offline
For Sale Autometer phantom 0-100 fuel psi gauge, wiring and sender. Juiced408W Electronics and Entertainment 5 01-15-2011 02:35 PM
fuel pressure regulator gauge? 97stanger97 GT & SOHC 4 01-14-2011 07:29 AM
Possible GP for A-Pillar gauge pods (full length replacement)! "approved" RoadRash GT & SOHC 131 04-26-2002 06:34 PM
air/fuel gauge wiring dugiewugie Electrical & Wiring 7 01-14-2002 10:43 PM
Serious questions dilemma about mechanical oil PSI gauge and DOHC oil PSI readings Cobra Jet NJ GT & SOHC 11 12-14-2001 04:19 PM
