Fuel tank wiring harness help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 03-24-2011, 10:24 PM Thread Starter
Pulling power from the pigtail harness on top of tank, to supply hot to the external Holley fuel pump. I don't have 12v anywhere. I used to have power before the winter, but now nothing. I can see where the harness runs above the tank and disappears. Any suggestions where this harness is powered from? I have Holley tied to a switch on the dash, which was installed when I got the fox. Would it just be easier to run a new wire from the switch, instead of trying to locate where I'm losing power at? It's an 85 model notch, so you can imagine what condition most of the wiring under the dash looks like. Please help! Thanks fellas.
bigbotl is offline
post #2 of 3 Old 04-17-2011, 02:48 PM
Warlock1's Avatar
Trader Feedback: (23)
This is for an 86, hope it helps.
http://www.veryuseful.com/mustang/te...ng-ECC-EFI.gif
Warlock1 is offline
post #3 of 3 Old 05-06-2011, 08:18 AM
hi
Do you have some problem in wiring harness?
Massachusetts Auto Transport|Michigan Auto Transport
ammaar555 is offline
For Sale NX Custom Wiring Harness NitrousExpress Advertiser's Showcase 1 12-22-2016 01:53 AM
Fuel Pump wiring issue? - help Ourobos Electrical & Wiring 10 03-05-2011 02:54 AM
Want To Buy 5.0 Fuel Pump Sending Unit Wiring Harness montelius Fuel System & Related 7 02-06-2011 06:56 PM
Fuel Upgrade Questions Cobra tank swap to 00GT orangemachine GT & SOHC 0 12-25-2010 07:14 PM
