I want to use a thermostat for my fan, not sure how to wire it! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 03-20-2011, 06:41 PM Thread Starter
Detroit306's Avatar
Something like this?
Painless Wiring 30111 - Painless Performance Electric Fan Thermostats - Overview - SummitRacing.com
My question is where would that switch go in the circuit? where do i run the wire from the sender to?
1992 Ford Mustang LX 'Vert
306, TFS ll cam, Track heat intake, Pro Topline 180 cc heads, Vortech S-Trim
Detroit306 is offline
post #2 of 3 Old 03-26-2011, 02:34 AM
GUNRUNINPONY's Avatar
Normally if you are using a stand alone system (IE just a fan and a relay, and not a full blown fan controller) then the temp senders wires will both be grounds, one side to a chasis/battery ground and the other to the relays ground. So in order for things to function correctly wire the relay ignition pwr to #86, Fan positive to #87, battery positive to #30, and temp sender to #85!
Heres a simple diagram to help you out!Google Image Result for http://www.banzai-racing.com/how_to/std_relay_connections_diagram.jpg
LMK if this helped you out!
A wise man once said "It's better to remain silent and appear ignorant, rather than speak and remove doubt!
91 GT, TT 306,TFS 170's, Track Heat,60lb inj, 150 shot, 3.27's, setting up for nice dd with Maximum Motorsport suspension.
GUNRUNINPONY is offline
post #3 of 3 Old 03-26-2011, 10:51 AM Thread Starter
Detroit306's Avatar
That makes perfect sense THANK YOU! As soon as it warms back up I'm gonna wire it
Why yes, it IS another Taurus Fan Install Post MFE General Mustang Tech 73 07-09-2018 11:50 AM
Adios old kitchen, it's been a fun-filled disgusting last 3 years. Dave88LX Lounge 258 05-05-2011 09:09 PM
electric fan: fan speed controllers? BerniniCaCO3 General Mustang Tech 21 03-23-2011 09:29 PM
Manual fan switch...which wire? COBRASVT GT & SOHC 4 12-28-2001 09:47 AM
