cooling fan wont run - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 03-15-2011, 05:55 AM Thread Starter
svt_cpe's Avatar
I have a 96 gt. The cooling fan won't turn on like normal. I have replaced the ccrm,ect and high pressure a/c switch with new parts all fuses are good. Nop luck. If I turn on a/c fan runs if I unplug the ect fan runs. Any other time it won't run car just runs hot. I want to fix it right. No red neck toggle switches. Please help.
03 true blue gt vert
02 red lightning
97 rio red cobra s-trim. 500rwhp w/4:10 gear and irs
svt_cpe is offline
post #2 of 2 Old 03-26-2011, 03:32 AM
GUNRUNINPONY's Avatar
Check the ect for proper function, it sound like it may be bad and the pcm is defaulting to protect the engine when you unplug it! Disconnect the ect and test the sender with a DVM. It should read like 2200-2700 ohms at 70 deg. and 290-350 ohms at 175 deg., if you get no reading then its probably the culprit! LMK if this helped!
A wise man once said "It's better to remain silent and appear ignorant, rather than speak and remove doubt!
91 GT, TT 306,TFS 170's, Track Heat,60lb inj, 150 shot, 3.27's, setting up for nice dd with Maximum Motorsport suspension.
GUNRUNINPONY is offline
96 gt cooling fan svt_cpe GT & SOHC 10 03-16-2011 10:28 AM
For Sale 94-95 Mustang GT Electric Cooling Fan 1slowhatch Electronics and Entertainment 3 12-14-2010 12:14 PM
HELP! Cooling fan problems! RedTwilight SVT & DOHC 5 12-10-2010 07:31 AM
Anyone try a VW Cooling switch to control a 2-speed fan? Nitrous SSC General Mustang Tech 17 11-19-2010 11:01 PM
