Turn the key no start. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 03-14-2011, 07:55 PM Thread Starter
Have a new battery and can start the car by jumping the solenoid. So that should rule out the starter.
Turn the ignition and nothing happens.
CLutch neutral switch?
beaker2008 is offline
post #2 of 2 Old 03-31-2011, 01:52 PM
GUNRUNINPONY's Avatar
Try bypassing the clutch switch with jumper wire, also check for a start signal to the solenoid. Rule out the clutch switch first though!
A wise man once said "It's better to remain silent and appear ignorant, rather than speak and remove doubt!
91 GT, TT 306,TFS 170's, Track Heat,60lb inj, 150 shot, 3.27's, setting up for nice dd with Maximum Motorsport suspension.
GUNRUNINPONY is offline
Turn the key and all I hear is CLICK bandb Electrical & Wiring 3 03-31-2011 01:55 PM
Who has access to Oasis reports? straightliner1 Lounge 4 02-28-2011 01:19 PM
For Sale Fully Built 408 Turn key slopez Windsor Engine Parts 10 12-13-2010 08:58 AM
For Sale Turn Key 347 n2omaverick Windsor Engine Parts 0 12-12-2010 10:12 AM
Last minute advice? About to turn the key on with the Heads and cam I just installed FastDriver 5.0/5.8 Engine Tech 4 12-29-2001 07:13 PM
