03 cobra seat into a fox - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 03-02-2011, 07:31 PM Thread Starter
teal_93's Avatar
I just won the bid on eBay for a set of 03cobra seats for my 93 cobra, Noe the question is what do I need to do to make the electric driver side seat work? Will it plug right up or do I need to do something else, sorry If I posted in the wrong area, u just figured it would be in th electrical area I would get the answer, thank you
teal_93 is offline
post #2 of 5 Old 03-03-2011, 05:28 PM Thread Starter
teal_93's Avatar
Bump
teal_93 is offline
post #3 of 5 Old 03-03-2011, 09:00 PM
I just picked up a set of seats from an 03 V6 car. The adjustment motors/wiring are probably the same. The only input mine has on the bottom is a single, 4-pin plug. Here's a general layout:
Pin 1: | Pin 2:
Black | Brown w/blue stripe
Pin 3: | Pin 4:
Green | Green
I tested the pins with my multimeter. Pin 1 and Pin 3 are for the power adjustments (all of them). Pins 2 and 4 go to the seat belt buckle lock for the "plug your seatbelt in you idiot" light on the dash. I just cut the wires off the back of the plug for Pins 1 and 3 and put on some spade connectors. My car has power lumbar, so I'm going to hack off that plug and put on the female spade connectors and plug it all in that way.
I do plan on extending the wires on the female side as the wiring harness on the seat is pretty hard to work around. There isn't much slop in it. If you want, I'll post up pictures of what I did after I've confirmed that they fit and work. Not sure when you're looking to install them though. I'm going to try to get mine in either tomorrow or this weekend.
1993 Mustang GT - Sloppy Horse - SOLD
1994 Mustang GT - Dedicated Racear - Full MM catalog with 03 Cobra IRS - Codename: Rigid horse
93twotonegt is offline
post #4 of 5 Old 03-03-2011, 11:02 PM Thread Starter
teal_93's Avatar
Pictures would be great I'm going to try to install next weeknd I'm out doing some training for a week
teal_93 is offline
post #5 of 5 Old 03-04-2011, 06:32 PM Thread Starter
teal_93's Avatar
Can a fox bracket be mounted on the seats and use the same plug the orignal seats where using?
teal_93 is offline
Junkyard Horsepower SUMMARY! slo5oh 5.0/5.8 Engine Tech 231 01-30-2015 11:35 PM
For Sale Lots of SN95 GT & Cobra Parts bmwm3 Modular Engine Parts 26 03-26-2012 04:03 PM
Want To Trade Trade my '97 Cobra Vert for your Built Fox Insignificant Other Fords and Trades 2 01-20-2011 11:42 AM
Anyone have aftermarket seat belts in Fox? sozzyber General Mustang Tech 6 01-11-2011 08:34 AM
For Sale trade 1997 cobra with mods for fox body 1990mustanglx5.0 Other Fords and Trades 25 12-12-2010 06:24 PM
