electric fan power - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 02-28-2011, 02:40 PM Thread Starter
electric fan power
hi guys im installing a electric fan in my 90 gt i ran the constant hot to the hot side of the starter relay i was wondering where the best place to get key on power was from
bowtech1 is offline
post #2 of 6 Old 02-28-2011, 09:08 PM
anywhere on the fuse panel that is key on power(ecu fuse) trigger wire for relay does'nt draw much power.key foward key-on only. if your controlling the fan via a temp probe, you can trigger it from a constant hot fuse to run the fan till the motor is cool.. or you can trigger it from a key-on fuse(radio,wiper,ecu,fuel pump).. make sure you have a hi output alt. the 80 amp oem is not enough at idle.
90 coupe, 302,9.7 comp,scat rods, ported windsor sr.'s(286 [email protected]" 2.05/1.60),tfs stage 3 cam,
funnel web, 750dp,c4/4000,4.30 gears, aeromotive 140 pump-motor/holley red for nitrous, 16 gal. cell, 2 stage nitrous,M/T 28x9 et drag,5" cowl hood.
tim harris is offline
post #3 of 6 Old 03-01-2011, 03:53 AM
stangbanger88's Avatar
i ran the hot to the positive terminal on the bat. the the cold threw a high amp in line fuse. ran the wire from their to the interior of car threw a fliped high amp switch next to the shifter.
88 LX Turbo, C4, H.C.I.---SOLD
97 COBRA, Vortech, T56, Forged, 445/438
stangbanger88 is offline
post #4 of 6 Old 03-02-2011, 02:55 PM
Did you use a relay?
With a relay the whole idea is using a small source to control a larger voltage so there would be no need for a High amperage switch.
If you didnt use a relay I would suggest it, I had one friend burn up a high amperage switch when he tried it w/o a relay. He also noticed the fans spun faster when he switched to using a relay.
1999 Mustang "V6" - Microsquirt Powered LS 5.3, 76mm On3 Turbo (Soon to Be Replaced), Turbo 400 w/ RMVB, Strange 31 Spline S/S Axles with Auburn Diff, 275/60/15 on 15x10" with Skinnies up Front
GearGuy2001 is offline
post #5 of 6 Old 04-09-2011, 04:46 PM
Thermostatically Controlled Electric Fan Upgrade - Muscle Mustangs & Fast Fords Magazine
I read the article and followed it to a T. My fan is working great. I also upgraded to an aluminum radiator and PA Performance alternator
bgoins is offline
post #6 of 6 Old 04-09-2011, 05:09 PM
use a relay for sure. get a 50-70 amp relay off of Ebay 8ga wire from battery to relay thru a same size fuse(stereo amp fuse will do)8ga to fan from relay. 16 ga wire to trigger wire on relay. use either a switch or (better)thermo switch of your choice. the larger wire runs cooler and spins them faster.
FR500TT Big Bore Boss-Stroked and Boosted w/Ethanol! Turbo98 SVT & DOHC 359 12-10-2012 09:05 PM
For Sale 94-95 Mustang GT Electric Cooling Fan 1slowhatch Electronics and Entertainment 3 12-14-2010 12:14 PM
I need an easy electric fan to install... austin flash 5.0/5.8 Engine Tech 6 05-22-2002 05:42 PM
Electric fan statistics needed! Vettkilr 5.0/5.8 Engine Tech 10 12-19-2001 12:54 AM
